1986 Dodge Daytona
1986 Dodge Daytona 4 cyl Front Wheel Drive Manual 100000 miles
my alternator is new as well as my battery, and it seems to be charging just fine as long as there's not a load on. Such as I can only one thing at a time: headlights really kill the amps put out it tends to sit right where the indicator turns red. Where should I start to look for the problem? I tried running a straight wire (with a 70 amp fuse on it) straight from the alternator feed to the positive terminal, but it didn't help. My turn signals and wipers are still slower than they should be, and the lights aren't as bright as they should be, oh yeah and I also tried running a whole different ground from the alt. As well but to no avail.
March 15, 2008.
Eaqsiest way is to call dodge dealer with the vin and tell them you want to get a price on one. They will look it up and then ask them for the part number. They will most likely give it to you
Mar 28, 2008.
