1998 Dodge Dakota Repair Question
1998 Dodge Dakota engine choking please help
1998 Dodge Dakota 6 cyl Four Wheel Drive Automatic 172000 miles
motor cuts out in drive looses horse power put it in neutral and rev the engine couple times and put it back in drive its fine. also some days when its wet or hot out or a combo of both does the same thing. when i get a diognostics check comes back with nothing. im told the computer may need to be replaced. where and how much can i get the compter replaced?
also it has been sitting for 6 months bc the problem has been getting worse spark plugs have been replaced almost sounds like its not getting enough fuel like its choking. the computer may be sending wrong signals im told.
any help will be great bc if it cant be fixed im going to have to sell it and get another vehilce its my primary source of transpertation.
Answer
Highly unlikely it's the computer. GM has a ton of trouble with engine computers, but not Chrysler.
An incorrect reading from the MAP sensor will affect fuel metering, but as long as the incorrect readings are within normal limits, it won't set a diagnostic fault code. This can cause a gradual or smooth loss of power, but not a sudden cutout like turning off the ignition switch.
Based on the mileage, you might suspect a plugged pickup sock in the gas tank. They will actually cause a problem when the largest volume of fuel is pumped which is, are you ready for this? . . . When you're coasting. If it runs better when you're accelerating, suspect the sock, and have the tank steam cleaned. This happened on my 1988 Grand Caravan. Ran great on the highway.
Older Dakotas had trouble with worn bushings in the distributor. The shaft would wobble causing surging from changing timing. It usually didn't cut out completely because it only affected a few cylinders, depending on which way the shaft moved within the pickup coil.
The pickup coil can develop breaks in the wires from heat. Your timing is computer-controlled, but on older engines, the pickup coils were mounted on a movable plate. As the plate moved to change timing, the pickup coils would flex, leading to broken wires. When it moved just right, the engine would cut out instantly.
Try a MAP sensor first, and the engine computer last.
caradiodoc
