1995 Dodge Dakota Repair Question
Topics covered: Glove box, Blower motor, Dashboard.
Asked on September 22, 2010
1995 Dodge Dakota Blower motor resistor location
Heater problem
1995 Dodge Dakota V8 Two Wheel Drive Automatic 260000 miles
I just bought a replacement resistor for my blower motor. I am assuming based on research that its location is somewhere behind - or under - the glove box. Can I replace this without pulling the entire dashboard, and if so, how?
Answer
Replied on September 22, 2010
Hi
Yes behind glove box can remove box to access just left of motor in air plenum. No need to pull dash. What is problem high speed only?
Hope this helps
Thanks for donate
Thanks, this is the help I needed. Blower problem progressed in steps- first, only two speeds, then one, then none.
When you get to resistor check voltage from switch
