How do I replace the fuel pump?
CHRISMFANNON
  • 1998 DODGE DAKOTA
I recently ran it out of gas and ever since it seems to have noticeably less power. I really doubt the pump needs replacing but since the only fuel filter is on the end of the pump, I need to know how to get it out. Maybe remove the bed?
Tuesday, November 27th, 2007 AT 8:36 PM
BLACKOP555
  • 10,371 POSTS
Running pumps down that low with no gas to cool them is a sure fire way to ruin a pump, especially one over 100k miles. replace the fuel filter inline between the tank and the engine first, if nothing then drop the tank and you can choose to change the fuel pump filter or replace the pump. Here is a guide to help walk you through the repair with diagrams below to show you how on your car. I have also included a video on how to drain the gas out.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://youtu.be/Q5MH2gnyFH0
Tuesday, November 27th, 2007 AT 8:42 PM
JOSHGYORK
  • 1998 DODGE DAKOTA
  • 6 CYL
  • 56,500 MILES
I need to change the fuel pump on my '98 dodge dakota sport and I do'nt now how.
Saturday, August 17th, 2019 AT 12:38 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Depressurize the fuel system.
Drain the fuel tank.
Remove the fuel tank from the vehicle.
Disconnect any lines that may remain attached to the pump.
Thoroughly clean the area around the pump so that foreign matter won't fall into the tank when the unit is removed.
Check the top of the pump for arrows or alignment marks. Check for corresponding marks on the tank itself. Alignment of the pump is important for routing of wiring and lines. Matchmark the pump and tank as reference for assembly.
If the pump is equipped with "fingers" and "finger locks", apply some lubricant to the assembly.
Remove the pump locknut. Some units are fitted with a lock tab. Pry it back while removing the locknut.
INSTALLATION:
Clean the filter at the bottom of the module.
Reverse the removal procedure.
Use a new gasket.
Align pump and tank marks to ensure correct routing of wires and lines.
If the locknut is the type without fingers and finger locks, tighten the nut to 40 ft. Lbs. (54 Nm).
Thanks for using 2CarPros. Com!
ROBSWEITZER
  • 1996 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 200,000 MILES
What is the best way to replace fuel pump, an do you have instructions, on how to
  • 108,328 POSTS
The pump is in the fuel tank. The easiest way to replace it that I have found is to actually remove the truck bed. There are 8 bolts that hold it on (which should come out easily) and then just disconnect the wiring to the rear tail lights and the filler tube at the fill location (3 screws I think). Have a friend help you lift it off and you have full access. Because I've done them before, it takes me about half an hour to complete. Otherwise, you will be dealing with the rusted fuel tank straps that always seem to break, trying to muscle out the tank, and then praying that the plastic tank doesn't crack when you tighten it back into place.
Let me know if you have questions.
KENMOHR
  • 1996 DODGE DAKOTA
Engine Mechanical problem
1996 Dodge Dakota V8 Four Wheel Drive Automatic
I'm looking to replace the fuel pump on the above '96 Dakota. I've seen repair kits available. The question I have is my original fuel pump housing seems to be molded or compressed together. Is there a special trick or tool to seperate it in order to retrieve and replace the internal parts?
Saturday, August 17th, 2019 AT 12:39 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Would be much easier and about same price just to purchase a used fuel pump assembly with warranty and replace old assembly.
SMOKEPOL;E HUNTER
  • DODGE DAKOTA
I have a 1996 Dodge Dakota 3.9 with 150,000 miles.
The fuel wore out and I was able to find one at the
salvage yard. This is a walbro pump in a 22 gallon tank. The replacement pump is a 6 pin, the pump being replaced is a 4 pin. How do I fix this.
MERLIN2021
  • 17,250 POSTS
Go to the parts store and buy the right one, or if you want to gamble on a used fuel pump return to the junkie and have them pull the right part!
PORTERVILLEBAIL
  • 1995 DODGE DAKOTA
  • 6 CYL
  • 200,000 MILES
Fuel gage stuck on 3/4 tank on 1995 dodge dakota( replaced fuel pump& panel)
JDL
  • 16,098 POSTS
The wiring for the sending unit at the tank, take it loose, you can use different size resistor for full and empty, key on, see if gage reacts. I'll find the wiring diagram. You can get resistors at radioshack, doesn't cost much. Get a resistor close to ohms spec, if you want to test. Some people don't want no part of testing. That's up to you.
JDL
  • 16,098 POSTS
I don't know if you replaced the sending unit? With sending unit unplugged, key on, the gage should go to empty.
The wire colors for sending unit, one wire is yellow, the other wire is lite blue with black tracer. If you use resistor for full or empty, between those two terminals, key on, the gage should react.
PORTERVILLEBAIL
Fuel pump and sending unit is one piece and new in tank.
PORTERVILLEBAIL
Fuel pump and sending unit is one piece and new inside of the tank
JDL
  • 16,098 POSTS
Ok, I'd have to do the other testing at the connector. Some makes and models, you can replace the pump without replacing the sending unit.
CARLEY
  • 1992 DODGE DAKOTA
Need to replace fuel pump or just clean fuel tank out
BLACKOP555
  • 10,371 POSTS
When you replace the pump a good idea is to drop the tank. And scrub the tank out good as to prevent the new pump from being contaminated
KUSHAL
  • 1994 DODGE DAKOTA
  • 6 CYL
  • 95,000 MILES
How to replace a fuel pump
Saturday, August 17th, 2019 AT 12:40 PM (Merged)
Release fuel pressure, disconnect negative cable from battery-remove fuel from tank unstrap it remove fuel pump
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_pressure_release_1.jpg
WVHOLLERMAN
  • 1991 DODGE DAKOTA
1991 Dodge Dakota V12 All Wheel Drive Manual
i have a 91 dodge dakota 3.9 tbi. I hadan intermiten fuel problem that has become all time now. I have replaced fuel pump, filter, regulator, hal effect, coil computer and still cant get fuel from injectors, I have went threw the wiring harness and cannot find any problems with it please help if you can
