limp mode repair ?
2010 CHRYSLER TOWN AND COUNTRY
81,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
SAINTRAIN
We have the Touring model. We have owned it one year, since 74,000 miles. A few days ago, July 25, 2018, at end of thirty mile trip, transmission, all of a sudden would not go into fourth gear. Drove thirty five mph home. The check engine light did not come on. The next day no problem, however, drove fine but the CEL did come on. Took to mechanic anyway and two codes appeared: P0734 and P0792. This seems electrical not mechanical, as it happens "randomly". It mechanical, would not it happen most of time? Driving home from mechanics, problem occurred immediately thirty five mph home. However, stopped four miles from home, turned off engine waited ninety seconds, restarted and drove home with no problems. I drive this van with young granddaughters/car seats What is the repair? Electrical or mechanical? Replace sensors, etc., or rebuild, replace transmission? Is there a true fix or is this van a dangerous piece of junk? Replies much appreciated. Sent July 31, 2018.
Jul 31, 2018 at 3:09 PM
  • CAR REPAIR CONTRIBUTOR
Good afternoon.
Below are the description and possibilities.
You need to take it to someone who will do the proper diagnostics to determine the failure. Clearing the codes does nothing as the issue needs to be addressed.
It could be electrical or mechanical as the charts show.
P0734
Descriptor
Gear Ratio Error In 4Th
Probable Causes
Code Is Not Matching in Service Info File
Intermittent Gear Ratio Errors
Related Transmission DTCs Present
Transmission Mechanical Condition
Transmission Solenoid/Pressure Switch Assembly
Flow chart
Theory of Operation
The transmission control system uses three speed sensors, one to measure input rpm, one to measure Transfer Speed output rpm of the main transmission assembly, and a third to measure the final transmission output rpm. These inputs are essential for proper transmission operation. Therefore, the integrity of this data is verified through system checks. When in gear, if the gear ratio does not compare to a known gear ratio, the corresponding gear ratio error trouble code is set. The transmission will go into Limp-in mode after four gear ratio error events occur in a given driving cycle.
- When Monitored:
The Transmission gear ratio is monitored continuously while the transmission is in gear.
- Set Condition:
If the ratio of the Input RPM to the Output RPM does not match the current gear ratio when compared to the known gear ratio.
Always perform the 62TE Pre-Diagnostic Troubleshooting procedure before proceeding.See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Pre-Diagnostic Troubleshooting Procedure
1. CHECK IF RELATED TRANSMISSION DTCS ARE PRESENT
1. With the scan tool, read Transmission DTCs.
2. If any of these DTCs are present, perform their respective tests first.
Are there any Loss of Prime, Line Pressure Sensor and/or Speed Sensor DTCs present?
- Refer to appropriate diagnostic procedure in the Transmission category. If any of these DTCs are present, they will cause a gear ratio error. Perform the test for Loss of Prime first if it is present.
- Perform 62TE TRANSMISSION VERIFICATION TEST See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > 62TE Transmission Verification Test
- Go To 2
2. CHECK IF THE DTC IS CURRENT
1. With the scan tool, record the DTC Event Data, clear the DTC and road test the vehicle.
2. Try to duplicate the conditions in which the DTC originally set using the DTC EVENT DATA recorded.
Did the DTC P0734 reset?
- Repair internal Transmission as necessary. Check all of the components related to the UD, OD, DC and LC clutches. Inspect the Oil Pump and repair or replace as necessary. Refer to the Service Information for the proper repair procedures.
- Go To 3
3. CHECK FOR INTERMITTENT OPERATION
1. The conditions to set this DTC are not current at this time.
2. Check the gearshift linkage adjustment.
3. Gear ratio DTC's can be set by problems in the Input and Output Speed Sensor circuits. If the vehicle passes the Clutch Test and still sets a Gear Ratio DTC, check the Speed Sensors for proper operation.
4. Remove the Starter Relay.
CAUTION: Removal of the Starter Relay will prevent the vehicle from being started in gear.
WARNING: The Starter Relay must be removed. Failure to do so can result in possible serious or fatal injury.
5. Check the wiring and connectors for the Speed Sensors for a good connection, then perform a wiggle test using the Transmission Simulator, Miller tool #8333A and the Electronic Transmission Adapter kit.
6. This DTC can also be set under extreme temperature conditions, this is usually caused by an internal problem. Verify if the problem is only experienced under extreme hot or cold conditions.
7. With the scan tool, check the EATX DTC EVENT DATA to help identify the conditions in which the DTC was set.
8. Check for Service Information Tune-ups or Service Bulletins for any possible causes that may apply.
Were there any problems found?
- Repair as necessary.
- Test Complete.
792
P0792
Descriptor
Compounder Speed Ratio Error
Probable Causes
flow chart
P0792-COMPOUNDER SPEED RATIO ERROR
Theory of Operation
- When Monitored:
The transmission gear ratio is monitored continuously while the transmission is in gear.
- Set Condition:
If there is an excessive change in the Output RPM in any gear.
1. DETERMINING IF RELATED TRANSMISSION DTCS ARE PRESENT
- Go To 2
2. CHECK TO SEE IF P0792 IS CURRENT
Did the DTC P0792 reset?
- Repair internal Transmission as necessary. Check all of the components related to the DC and LC clutches. Inspect the Oil Pump and repair or replace as necessary. Refer to the Service Information for the proper repair procedures.
- Go To 3
3. Gear ratio DTCs can be set by problems in the Input and Output Speed Sensor circuits. If the vehicle passes the Clutch Test and still sets Gear Ratio DTC, check the Speed Sensors for proper operation.
6. This DTC can also be set under extreme temperature conditions. This is usually caused by an internal problem. Verify if the problem is only experienced under extreme hot or cold conditions.
7. With the scan tool, check the DTC EVENT DATA to help identify the conditions in which the DTC was set.
- Test Complete.
Jul 31, 2018 at 4:01 PM
SAINTRAIN
I am greatly appreciative of your detailed response. It appears the diagnosis is complex and time consuming. What amount of time is involved in such detailed diagnosis and how much would diagnosis alone cost a consumer, before any repairs begin?
If "Transmission Mechanical Condition" is found to be the problem, does this diagnosis require a rebuild or "new" transmission?
Jul 31, 2018 at 7:53 PM
The diagnostic is about a two hour job to do it properly. That would be around $200.00 to $250.00.
If it is mechanical, then yes, it is a rebuild. That would be around $2,000.00 to $2,500.00.
Aug 1, 2018 at 1:48 AM
ALEXW_159
  • 10 POSTS
Hey 2CarPros community,
Our van is in limp mode right after startup and therefore will not shift.
Engine starts perfectly fine however.
With an OBD scanner I checked the input and output speed sensors. Both work fine and have an output to the computer (speedometer works as well).
I also checked the EATX relay. It works. Has a 12 volt supply. And we also checked the control and two output wires between the relay and the TCM. They are fine as well (Pin 15, 16 and 17 at the 60-pin connector at the TCM).
That is what I have so far.
The next things I thought about to check are the TCM and PCM somehow, right?
What tests would you recommend and suggestions do you have?
Or any other ideas?
I would really appreciate any ideas, support and posts here.
I am looking forward to find out some new information and finally find the problem/solution even for this problem.
Thank you all in advance!
- Alex
Dec 26, 2020 at 11:03 AM (Merged)
CARADIODOC
  • 34,309 POSTS
By "does not shift", do you mean it stays in second gear?
You already found the first clue in that you do not have to be moving for it to go to limp mode. That eliminates slippage in one of the clutch packs. Since you have a scanner, use it to read and record the diagnostic fault codes in the Transmission Computer. Those will tell us which circuit needs further diagnosis.
ALEXW_159
  • 10 POSTS
Correct, it stays in the second gear.
And it is in limp mode right after startup without any initial movement needed, right.
A friend with a scanner checked the sensor outputs, but he is out of reach right now and it probably needs a couple more days until I will see him (and the scanner) again.
Might there be something that I can check before or meaningful check I can do without knowing the error codes for now?
CARADIODOC
  • 34,309 POSTS
Not to my knowledge. If you have a simple fault code reader, you can use that to see if anything useful comes up. The problem is you need to read the codes in the Transmission Computer, and most code readers only read them in the Engine Computer. Typically when there is a code in the Transmission Computer that puts it in limp mode, that results in seriously-decreased fuel mileage, and therefore, increased emissions, and any fault code related to something that could adversely affect emissions will turn on the Check Engine light. The fault code found in the Engine Computer then is code 700 which just means there is some other code in the Transmission Computer. Without knowing the exact code number, there is no practical way to know where to start the diagnosis. All we know is it is going to be electrical in nature.
Some of us would be tempted to just start replacing random parts, but you are much better off waiting for the scanner. Every new part introduces a new variable and potential second problem. Simply unplugging a connector and reconnecting it can temporarily solve a problem, and that is exactly what we do not want to have happen. We want to know which circuit has the problem, and we want to know exactly what we did to make the problem go away, so we know what the proper fix is.
ALEXW_159
  • 10 POSTS
Sounds meaningful!
I will try to get the scanner as soon as possible. :)
  • 54,354 POSTS
Cheers, Ken
ALEXW_159
  • 10 POSTS
For sure.
I will have the codes to post them tomorrow (Wednesday) around 1:00 pm.
Thanks, Alex
ALEXW_159
  • 10 POSTS
TCM Error Code is:
PO605 Internal Transmission Controller - ROM Fail
So the TCM itself needs probably to be replaced, right?
  • 54,354 POSTS
Yep, that is what that means. The computer is having issues. Here is the location so you can replace it I would try a used one. The TCJM is subject to water damage so it makes sense.
Cheers, Ken
ALEXW_159
  • 10 POSTS
Okay. Sound reasonable. Thank you.
I will see what I can do on the weekend and let you know what the result will be.
ALEXW_159
  • 10 POSTS
There are a lot of posts that say that the P0605 could also be caused because of wiring problems rather than module failure. Especially 12 volt supply wiring and ground wires (potentially also the module output).
This could also be still the case for me, right?
I will try to get a TCM from the junkyard on the weekend to somehow figure it out.
References:
https://www.2carpros.com/questions/2004-chrysler-town-country-p0700-p0605
https://repairpal.com/OBD-II-Code-P0605
https://www.obd-codes.com/p0605
  • 54,354 POSTS
It could be the the wiring but it sounded like you checked that in your first post. I will be happy to back over it will you with this guide and the TCM wiring diagrams below.
Please check power and grounds and test through the transmission range sensor.
Please run down these guides and diagrams and report back.
Cheers, Ken
KEN KILMER
the overdrive is not working at all. Rpm's goes up near red line at forty five mph. I believe the van is now in limp mode.
  • 54,354 POSTS
Okay the first thing we need to do is code for codes here is a guide to help you see whats going on. It sounds like a transmission shaft speed sensor.
Please run down this guide and report back
Cheers, Ken
ALEXW_159
  • 10 POSTS
So, we replaced the TCM with a $35.00 used one from the junkyard on the weekend and that worked! Just replaced the TCM, plugged it in and it immediately worked.
The one I got was from a 2003 Grand Caravan if I remember right. It was the best one we found and it was in an pretty good condition.
I could not found holes or something similar on the old one, but it already looked a bit corroded.
We also checked the wires again, but they were still fine and looks as they are in a pretty good shape still.
So it worked all out for me!
Thank you very much to all people here for the great and fast support!
And we hope that this post might also help some other guys.
Thank you to 2carpros!
KEN KILMER
The check engine light has not come on. No codes are available. The only way I know what happened is that the RPM is much higher then normally would be while the van is running. Thank you for your assistance. Ken Kilmer
  • 54,354 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
  • 54,354 POSTS
With no codes it sounds like you could have a vacuum leak. Here are two guides to help you see whats going on.
https://www.2carpros.com/articles/engine-idles-too-high
and
Please let us know what you find.
Cheers, Ken
SARAHNICOLE
Transmission problem
1996 Chrysler Town and Country Front Wheel Drive Automatic 156000 miles
Transmisson has been rebuilt but still stuck in 2nd gear... I have heard it could be my selnoid or the input output sensors... HELP ME please
Dec 26, 2020 at 11:04 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5fa558fc33="sarahnicole"]Transmission problem
Transmisson has been rebuilt but still stuck in 2nd gear... I have heard it could be my selnoid or the input output sensors... HELP ME please[/quote:5fa558fc33]
Hello Sarah,
The Input and Output Sensors should have been replaced during rebuild.
The other cause for your problem is the TCM (Transmission Control Module) which is the computer that controls the transmission.
JUANB711
Transmission remains in limp mode and does not shift. After clearing the codes, the code for the EATX relay continues to show up. I have been told that the failure of this relay may cause the transmission to behave in this manner. So, hopefully, the easy fix is to replace this relay. However, I don't know where this relay is located, and no manual or diagram that I can find lists it. I suspect that it is probably listed somewhere by some other name that I don't recognize. I have seen under hood pictures that list both a safety shutdown relay and an automatic shutdown relay, but neither of those sounds like it would be the right relay. Now, of course, comes the actual question. Where is the EATX relay located on a 1992 Chrysler Town & Country van? Thank you for your help.
CARADIODOC
  • 34,309 POSTS
The closest I have is a '94 service manual, but it should be the same. There's two rows of four relays under the hood. On the shorter side of the fuse box, next to the latch, the relays are automatic shutdown, low radiator fan, fuel pump, and radiator fan ground. Just off center in the second row is high radiator fan, AC clutch, backup lamps, then the EATX relay. In the wiring charts they list the EATX relay as the "safety shutdown" relay.
There's a couple of different fault codes related to the relay. If you tell me the exact code number, I may be able to offer some suggestions.
