Front Hub Bearing
PAULARCE
  • 2002 CHRYSLER PT CRUISER
  • 4 CYL
  • MANUAL
Which size front hub bearing for a manual transmition pt cruiser do I need to get?
Monday, January 24th, 2011 AT 3:38 PM
CARADIODOC
  • 33,752 POSTS
Here are the hub bearing on amazon for $35.00
https://www.amazon.com/WJB-WA512167-Assembly-Reference-BR930173/dp/B00A702PU6/ref=sr_1_2?s=automotive&ie=UTF8&qid=1512341181&vehicle=2002-39-2620&sr=1-2&ymm=2002%3Achrysler%3Apt+cruiser&keywords=2002+CHRYSLER+PT+CRUISER+hub
Here is a guide that will give you an idea of how to change them out
https://www.2carpros.com/articles/bearing-hub-replacement
This will show how the front is done
https://www.2carpros.com/articles/how-to-replace-a-cv-axle-bearing
Here is how it will be on your car (below)
Check out the diagrams (Below)
Cheers
Monday, January 24th, 2011 AT 4:29 PM
PAULARCE
I just call the dealership and they want $450.00 to do the job I can't believe how much I saved by using this site! They said something about 39mm bearing? I love 2Carpros
Monday, January 24th, 2011 AT 4:54 PM
CARADIODOC
  • 33,752 POSTS
Are you referring to the axle nut? I can't think of anything that is 39 mm on the bearing assembly. It is probably the outside diameter of the bearing.
Caradiodoc
Monday, January 24th, 2011 AT 4:59 PM
PAULARCE
Okay thanks again CARADIODOC I will tell my people about you guys :)
Monday, January 24th, 2011 AT 5:25 PM
TONY1TON
  • 4 CYL
  • FWD
  • 48,000 MILES
Suspension problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 48000 miles
Do you know anything about two differant front hub bearing sizes?
Sunday, December 3rd, 2017 AT 2:55 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
I believe I will need more information here to better assist you. Could you please be more specific with the question? Do you mean one side of your vehicle has a different size hub bearings?
Thanks for using 2carpros. Com!
MIDAS414
  • 17 POSTS
There are 2 different size bearings dealership parts department would know which one you needed from your vin number ran into this problem a few times because there are two different bearing due to two different rim sizes.
AMYWHITE2000
  • 4 CYL
  • FWD
  • 62,850 MILES
Suspension problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 62,850 miles
we have it all tore down but cannot get the old hub and bearing assembly off
BMRFIXIT
  • 19,053 POSTS
You may need one of these
https://www.2carpros.com/forum/automotive_pictures/99387_puller_1.jpg
T9323128
  • 2004 CHRYSLER PT CRUISER
Drive Train Axles Bearings problem
2004 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
As you can see, I have a 2004 PT Cruiser, I need to know if the left side hub bearing is a job I can handle or not. I've pulled and installed engines, trans, rears, done clutches, etc. The mechanic wants close to 300 for the job, money being tight like it is I'll do it myself if not too difficult.
  • 108,269 POSTS
If you have a good repair manual, and you have done all the other things you mentioned, you will be fine.
