Serpentine belt replacement instructions please?
SHERIRAY
  • 2003 CHEVROLET VENTURE
Diagram on how to put the Serpentine belt?
Friday, April 9th, 2010 AT 3:16 AM
DAVEH429
  • 41 POSTS
Hello..
Below is a link to generic how to guide which is a good way to prepare and the diagrams attached have all the diagrams and instruction you need.
https://www.2carpros.com/articles/replace-serpentine-belt
Hope this helps with your repair, Please keep us updated on your repair outcome and do not hesitate to contact us again for further information or assistance.
Thanks for using 2CarPros.
Dave H
Monday, March 1st, 2021 AT 2:13 PM
HUBERTC
  • 2000 CHEVROLET VENTURE
  • 6 CYL
  • FWD
  • 180,000 MILES
Need to see a belt diagram.
Tuesday, March 2nd, 2021 AT 9:02 AM (Merged)
  • 52,797 POSTS
Good afternoon,
I attached the diagram for you below. It shows the location of the tensioner for you to release to remove the belt.
PBURDEAU
  • 1997 CHEVROLET VENTURE
  • 6 CYL
  • FWD
  • 142,000 MILES
Why would the fan belt come loose? Is it the fan belt or the pulley?
DENNYP
  • 1,823 POSTS
You probably have a bad pulley or a broken belt tensioner. A bad belt or incorrect belt size could cause it also.
PBURDEAU
I found out that the main engine pulley has moved outward and thats why the belt is falling off the other pulleys. The main engine pulley that is connected to the cranck shaft is moved out about two inches. Why is this. Is a bearing out? Or does it just need to be fitted again and bolted back up? I have a new fan belt and the spring pulley is working just fine it's that main engine pulley that is making my car not run.
Philip
Washington State
MASTERTECHTIM
  • 4,749 POSTS
Sounds like you have a bad harmonic balance. The pulley is actually bonded in rubber to part that is bolted to the crank. There is no fixing it, you must replace the harmonic balancer.
