Engine misfiring?
2000 CHEVROLET VENTURE
180,000 MILES
AMOS1976
when pressing gas to accelerate while driving van jerks like hell!!!! when u lighten up of gas it drives okay?
Mar 13, 2012 at 2:12 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
It sounds like the engine is misfiring have you done a tune up lately? here are to guides to help us fix the problem.
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Mar 13, 2012 at 2:15 AM
CHEVYFORLIFE
  • EXPERT
  • 33 POSTS
Does it happen worse when the van is warmer? If so the transmission pressure control solenoid is bad. I did a tune up which fixed my problem.
Mar 13, 2012 at 4:07 AM
DJCL
  • 767 POSTS
Is the check engine light on is so check codes it can tell you the cylinder
Mar 21, 2012 at 3:12 AM
JAMESMARC11
I am having trouble with this site. I ask a question 2 days ago and got a short answer which I answered the questions and have not gotten a response. Help me with what I need to do next. I was asked if the coil and module were checked.
May 9, 2020 at 1:17 PM (Merged)
CARADIODOC
  • 34,309 POSTS
You should not be starting a new question because that's like starting a whole new conversation in a bar with different people. Once your first question was answered it goes off the list for others to see and respond to. That prevents a lot of people from giving you all kinds of different advice that makes your head spin, which is how most other forums work. Here, one person will stick with you until a solution is found.
By starting a new post we don't know the problem you're having, the engine size, observations, hints and clues, what you've tried so far and the test results, or why the reference to those parts was made. Donations are greatly appreciated but most of the experts here will put just as much effort into helping you if you don't make a donation. There are other things that can happen though. I was recently gone to a car show swap meet for five days, and just before that I was nursing a kidney stone for five days including numerous trips to the hospital. Due to the pain I really didn't care about turning on the computer. Stuff like that can happen so thank you for not being angry about the lack of a response. Sometimes we miss the automated e-mails directing us back to your post when you make a reply so the first thing you should do is post another reply on your original thread. If you can't find the e-mail message with the link to that thread, look in the section where questions are listed by manufacturer and model. I think those are in order by date so you shouldn't have to scroll far to find yours.
If you still get no response, you can send a help request to the site owners and they will contact the expert who originally answered your question. The site owners are very helpful and easy to work with. If you run into problems, let me know and I'll contact them on your behalf. They will also get another expert involved if necessary and they'll send them the link to your question.
JAMESMARC11
Initially the problem was no power when you accelerated,, especially if you push it hard. Misfires are the problem. So I bought a code reader. Says O2 sensors are bad, replaced them. No better. So in the last few months I have replaced the following: Plugs and wires, Cat. converter, fuel pump assembly in the tank, fuel pressure regulator, fuel filter, and last but not least the PCM. Nothing has made a difference. I have been to 3 different shops and had many "opionions" but it is as bad as ever. What do you think could be the cause?
codes never identify bad parts just failed systems.
Did anyone check the coil and module??? Did anyone do a compression test???
JAMESMARC11
Compression test was done and was ok. Coil not checked. What module?
JAMESMARC11
ASEMaster6371 -----I hope you get this response I think just like you asked,,,the coil could be the whole problem. What is the module you are referring to, I am not that familiar. In looking at parts for this car I see there are One coil for each 2 cyl. Is that right? How do you test for bad coil or coils? Thanks
DLOCKHART101
my van misfires when i am driving on the highway
JDL
  • 16,098 POSTS
Hello, how long since a tune-up, any codes? If only one cylinder has a problem, the misfire code might point you to the correct cylinder? I don't usually get that lucky, you got to start somewhere.
CORREIA324
[quote:d98218dbda="dlockhart101"]Engine Mechanical problem
2000 Chevy Venture 6 cyl Four Wheel Drive Automatic 11000 miles
my van misfires when i am driving on the highway[/quote:d98218dbda]
RIFLEMAN
  • 12 POSTS
Code p0300
I have been working on this for three years. I have tested coils 5.75 ohms on secondary and 1 ohms on primary coils. I have new plugs and wires. New intake gaskets, IAC, TPS, AIC. Map is good. Vacuum holding at 25 psi. Timing light shows cylinders one and five random misfiring. It also has a new cam sensor. Could a bad knock sensor be causing this. I tapped on the engine and no change in rpm's. Can you help thanks.
May 9, 2020 at 1:18 PM (Merged)
HMAC300
  • 48,601 POSTS
best thing here is to have a mechanic look at it he can freeze frame to see if a sensor is bad as they can cause the problem as well as injectors or a basic engine problem. these are very hard to find and having a mechanic do it actually will save money because you are not spending on parts that are probably good.
RIFLEMAN
  • 12 POSTS
Thanks. I was already contemplating on that. Most likely that is what I am going to have to do.
  • 54,354 POSTS
Please let us know what you find so it will help others.
Best, Ken
RIFLEMAN
  • 12 POSTS
Will do as soon as my work load changes. I have a few more things I'm going to test before I take it to the shop. I'll keep you informed. Thanks
ETZ
1997 3.4 Chevy Venture, with 118,000 miles. Recently replaced head and intake gaskets, plugs and wires. Engine starts and runs fine when cold. As soon as the engine warms up, a severe hesitation/ miss develops. Engine doesn't throw a code. Should the coils be replaced when the plug and wires were replaced?
[quote:187a95e495="co_ranger"]96 Ford Escort 1.9L - there is no spark at the plug. i tested the coil pack (16.8k on secondary and .6 on primary), and the timing belt is ok. there are other parts in the system like the ctankshaft position and eec modules. how do i test these? anything else i should be looking at?[/quote:187a95e495]
You need a break out box. Check the CPS and ICM before you get to the PCM. Inspect for damages/loose connectors.
  • 54,354 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
CO_RANGER
Found the CPS, reads 355 ohms. but cannot find any info on what it should read. Cannot find the ICM however, and hear that some of these had the ICM intergrated with the EEC.
RIFLEMAN
  • 12 POSTS
I did a few more test with the timing light. I found out as the van warms up coils 1 /5 starts randomly missing. I believe that I'm losing the secondary on the packs. I haven't had much time to mess with it. Soon as the weather breaks I'm going to replace all the packs with new ones. I tried ones from a junk yard but it ran worse. I'll let you know once I change them out. Thanks for asking.
[quote:931701513b="co_ranger"]Found the CPS, reads 355 ohms. but cannot find any info on what it should read. Cannot find the ICM however, and hear that some of these had the ICM intergrated with the EEC.[/quote:931701513b]
Try doing this:
Here is a little trick that will literally show you if a DIS module and its crankshaft sensor circuit are working: connect a halogen headlamp to the spade terminals that mate the DIS module to the coils. A headlamp is recommended here because it puts more of a load on the module than a test lamp. If the headlamp flashes when the engine is cranked, the DIS module and crankshaft position sensor circuit are functioning. Therefore, the problem is in the coils.
  • 54,354 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
CO_RANGER
Well, it ended up being none of that stuff. Corroded ground wire connection on the firewall. Thanks for your suggestions.
KEVIN599
i have tested the coils,ignition mod, cam sensor has been replaced, new plugs wires, and crank sensor. the fuel pressure is right were it needs to be and yet i still am running ruf and i am getting a p0300 code witch is random or multiple cylinder misfire
BLACKOP555
  • 10,386 POSTS
clean and inspect the MAF or MAP. is engine running hot or normal?
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
