black smoke out of tailpipe
1992 CHEVROLET VAN
BETHI
black smoke comes out of tailpipe, runs but wont stay running what could this be? when i back up it stalls,and it is a chevy and its white my wires have not been replaced in a long time but the spark plugs have could this be my fuel pump i just had it replaced 5 years ago what do you think please reply with the bestest possible answer high mileage please reply with the good answer and i drive it alot with my daughter and every time i start it it has black smoke coming out of the back and it smells like gas alot and stuff and recently black soot has been coming out of the tailpipe too it looks like oil and aloso please give me a good answer and or should i get rid of this van yes or no it stinks badly i have already fixed my fuel pump and i think something is wrong and it is clogged maybe it is my catillatic converter spark plugs have been changed recently and it stalls when i back up and black smoke has been coming out of tailpipe for about a year when i go from stopped at a light to going forward, what could be clogged in there and why is black soot coming out of the tailpipe at the back of the van thank you
Jun 30, 2013 at 2:28 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
It sounds like you have a fuel pressure regulator that has gone bad which is common on these cars. The diaphragm goes bad allowing raw fuel to be burnt.
Here is a guide that will give you some insight to the problem so you can get is fixed.
https://www.2carpros.com/articles/engine-black-smoke
and
Cheers, Ken
May 29, 2017 at 10:33 PM
MAGICCAR1
Engine Performance problem
1990 Chevy Van V8 Two Wheel Drive Automatic 172000 miles
After 15min. blows black smoke & dies. won't restart for a time.
May 29, 2017 at 10:33 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Is the service engine light on? Read the codes like this, post the results. It sounds like either the ECT(enine coolant temp) sensor, or an O2 sensor, too rich... Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
https://images.2carpros.com/forum/automotive_pictures/62217_Pre95GM1_8.jpg
Sounds like its running too rich
1.Fuel pressure not within specs.Can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
MAGICCAR1
code 12 &15
Thank You for the help
Rick
MERLIN2021
  • 17,250 POSTS
12 is nothing and 15 is the coolant temp sensor reading too low. change the sensor.
SPIKE NEES HELP
blowing flames and black smoke out tail pipes
Sounds like its running too rich could be caused by one of the following
1.Excessive fuel pressure can be cause by restricted fuel return line
3.Leaking injectors and fuel pressure regulator.
