Mechanics
CHEVY NO SPARK
1988 Chevrolet Truck
Electrical problem
1988 Chevy Truck V8 Four Wheel Drive Automatic 178000 miles
There is no spark at the plugs even after replacing ignition module, dist. Cap, rotor, and ECM. There is spark at the coil. The main reason why I changed the ECM was ALDL gives no response when a scan tool is connected but does flash a code 12 with the servise engine light (still nothing with the scan tool connected) This all started when in the morning I started the drove it 10 miles stopped got gas started right up drove it another 10 miles to a store came out 15 minutes later and it would just crank and not fire up. I would appreciate any suggestions of other areas to check.
Tdecker85087
November 7, 2009.
Hi tdecker85087 and TY for the donation
Check and test the distributor pick-up coil and air gap-also double check the cap and rotor contacts-if there's spark out of the coil-it should have spark at the plugs if cap and rotor good it has to make it out there to get to the plugs
DTC's
12
No Distributor pulses
13
Oxygen sensor
14
Coolant Temp sensor circuit
15
21
Throttle Position Sensor
22
23
Manifold Air temperature sensor
24
VSS (Vehicle Speed sensor)
25
32
EGR system
33
MAP sensor or MAF sensor depending on engine
34
35
Idle Air Control Valve
36
MAF Burn-off circuit
41
No Distributor pulses, cylinder select error
42
Electronic Spark Timing or Bypass fault
43
Electronic Spark Control fault
44
Lean exhaust
45
Rich exhaust
46
VATS system fault
51
PROM fault
52
CALPAK fault
53
System over-voltage
54
Fuel pump circuit
55
ECM fault
61
Oxygen sensor fault (degraded sensor)
Rasmataz
Nov 7, 2009.
AD
