I just bought this truck and the interior lights on a couple of different things when I bought it didnt work. I drive down a lot of bad dirt roads for my job and now the lights that didnt work before (button lights on my steering wheel) do and the 4x4 lights dont. Also this morning one of my fog lights was coming on and off. How can I fix the wiring so this doesnt happen?
SPONSORED LINKS
Thursday, March 5th, 2009 AT 8:02 AM
RACEFAN966
MECHANIC
Ok is sounds like you may have a body control module issure. The body control module controls interior and exterior lighting and more. If you have a digital multi meter and would like to do a couple of tests we can determine that. Get back to me.
SPONSORED LINKS
Thursday, March 5th, 2009 AT 10:39 AM
CODYBULLARD
MEMBER
I really appreciate your help but I dont have a digital multi meter, I went to auto zone to get them to use theirs and it was the $40 junk edition (I guess thats why they do it for free) and they said the one that I need is about $1500 and thats just not even gonna come close to affordable for me, so what can I do.
Tuesday, March 10th, 2009 AT 9:57 AM
RACEFAN966
MECHANIC
All you need is a 20 dollar or so digital multi meter. Here is a pic of what you can get so we can do some voltage and ohm's testing ok. Kinda like this one will work just fine. They are trying to sell you a scanner instead.
Tuesday, March 10th, 2009 AT 10:07 AM
CODYBULLARD
MEMBER
Thats alot cheaper I think I can handle that. Can I get one of these at auto zone or some place like that?
Tuesday, March 10th, 2009 AT 10:10 AM
RACEFAN966
MECHANIC
Yes you can get them at a parts store or home depot or a hardware store. Just make sure it is digital and that it has volts and ohm's and will work on a 12 volt system. Now most meters will not have a 12 volt setting it will be a 20 volt setting. This one has all the setting that we need and more for only about 21 dollars and tax. I hope you can blow it up some and see what I mean. I am not saying you don't understand what I mean I just know that sometimes a pic can clear it all up.
SPONSORED LINKS
Tuesday, March 10th, 2009 AT 10:30 AM
CODYBULLARD
MEMBER
Ok I got a Fluke multi-meter that my electrician buddy gave me and he said that it would work.
Friday, March 13th, 2009 AT 6:58 AM
RACEFAN966
MECHANIC
Ok first thing is you need to get access to the lower part of the steering column. On the left side of the column is the body control module. I will include a pic number 3 is the module and 4 is the harness to the module ok. So first I need you to see that the 3 orange wires to the module all have power and they should be hot at all times so the key doesn't need to be on for this. Just to let you know this module controls everything other then the engine electrical. I mean it runs the interior lights it runs the anti theft and door locks, sound system, wipers and washer and A/C and etc. Now get back to me with what you find and we will go from there.
Friday, March 13th, 2009 AT 11:07 AM
BOOTS FOX
MEMBER
1 POST
2005 CHEVROLET SILVERADO
V8
4WD
AUTOMATIC
73,000 MILES
When I turn the heater on it will not come on and the interior light will not come on as well
Monday, September 14th, 2020 AT 11:31 AM
(Merged)
MECHANIC
Have you checked fuses? If so, have you checked to see if the blower motor is getting power?
(Merged)
THETUCKA
MEMBER
1 POST
V8
2WD
AUTOMATIC
70 MILES
I have a 2005 chevy silverado with interior lighting problems. The courtesy light for when the door opens doesn't work when I open the door nor when the key comes out of the ignition like it used to. It does work fine when I unlock the doors using the remote. I also have a couple of lights out on the steering wheel that control the radio. Not sure if is related, but I recently had the gauge cluster replaced at the dealership due to a recall and everything worked fine before then.
(Merged)
HMAC300
MECHANIC
Ther are 2 fuses for the courtesy light they are 2B and 2C on the lower left fuse box. Unless there are loose connections from the the new gage cluster being replaced it would be either a door module or body module out of whack it seems. Unfortunately you need a tech 2 scanner to test these to see what's wrong. They are usually only at dealers.
(Merged)
HARVEYLOVE
MEMBER
1 POST
2002 CHEVROLET SILVERADO
V8
2WD
AUTOMATIC
157,000 MILES
I blew the fuse for the for the interior lights in my 2002 Chevy Silverado. I changed the blown fuse but the lights still wont come on.
SPONSORED LINKS
(Merged)
BMRFIXIT
MECHANIC
Recheck all fuses using a test light
check the bulb
any thing else isn't working
if all checked OK need the help of a scanner to test the relays , BCM module and wiring
(Merged)
RHERLING
MEMBER
V8
4WD
AUTOMATIC
150,000 MILES
Every time you open door I blow the the 15 amp fuse I have cheked all interior lights and cago plus under hood lights for bad wires or shorts all looks good
(Merged)
MECHANIC
Have you checked light sockets?
(Merged)
RHERLING
MEMBER
Yes all light socket that goes withthat fuse
(Merged)
MECHANIC
If you remove all light bulbs, will it still blow the fuse? Also, check the owner's manual and see what other accessories are run from the same circuit.
(Merged)
BJACOBSON39
MEMBER
1 POST
V8
4WD
AUTOMATIC
120 MILES
I have a 2002 chevrolet silverado 1500, my dome and interior lights are stuck on, I was wondering if there was a relay that would cause this problem?
Thanks
(Merged)
MIKE H R
MECHANIC
Check the courtesy light switch on the door, If one is broken and making contact and grounding out making the light stay on, also check the dash light dimmer switch to make sure it is off.
(Merged)
TYLERPOWELLS
MEMBER
1 POST
2000 CHEVROLET SILVERADO
V8
2WD
AUTOMATIC
125,000 MILES
The driver side door unlock button and window up and down buttons no longer light up. How do I fix this?
