Engine loosing power on acceleration?
CHEVYGUY4300
  • 2003 CHEVROLET S-10
I am loosing power reducing rpm's to 700, and when trying to accel, even the slightest the engine dies or wont accelerate over 2000 rpm's and backfires. I have replaced the fuel filter and fuel pump. Plugs and wires seem to check out fine. Any ideas?
Saturday, December 8th, 2007 AT 10:11 PM
Try checking the throttle position sensor, MAP/MAF sensors, to include a check on the exhaust system for restriction.
These guides can help is fix it
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Sunday, December 9th, 2007 AT 6:05 AM
CHEVYGUY4300
In reply to that, I did not provide the information that the vehicle will surge and be fine to drive occasionaly, It will drive then die out at a light when taking off on green. (Put head down, people dont like that) I Had the parts store pull codes, six different codes this morning all for o2 sensors, so I need to still replace the four of them. Can O2 sensors be responsable for this kind of behavior? Or are they sensing a larger problem causeing them to say the vehicle is running rich? Leading me to believe, how do 4 sensors go bad overnight, and could the catilac convertor possibly be to blame?
Sunday, December 9th, 2007 AT 7:10 AM
CHEVYGUY4300
It was the MAF sensor I got a new one and the power came back
Sunday, December 9th, 2007 AT 12:09 PM
AJSWEETWATER
I have an '03 Chevy S-10 with just over 70K miles Auto, 4WD, V6 4.3 that I just had a wire replaced that led to the coil pack(?). The truck started hesitating and eventually shut off. After replacement of said wire I have now noticed that the truck loses power up hills. I give it more gas and it slowly gains speed. Before it would jump and run! I also had a problem when I engaged the cruise control. The truck lost power going up slight grade and when the cc kicked in to get back to speed the engine revved to point of almost red line before I hit the break pedal to disingage. It did not pick up any speed during this incident. There is a dual exhaust on and I have noticed it is too quiet! The engine sounds like it is being overworked and exhaust pressure is from front not back of vehicle! Some rattling when I stop. This seems to come from below and not the engine. I have had 2 diagnostic tests in last 3 weeks and nothing showed up. Thought maybe it was catalytic but assume this would show on diagnostic test. Fluids are full and oil recently changed! No warning lights on. Any help appreciated!
Monday, December 14th, 2020 AT 9:08 AM (Merged)
RMCHAMBERS
I had an 88 S-10 and it had a very similar symptom.
Mine would rev, but generate so little power it barely moved. I got underneath and removed the O2 sensor and tried it again, the thing ran like a beast! Backpressure was the reason and a clogged catalytic converter was the cause.
I surmised that the O2 sensor had failed and the computer had wound up making the mixture excessively rich. Either that or some other fuel contaminant had clogged the cat. I replaced the cat and the O2 sensor and the truck ran well until I traded it in on a 2004 Colorado.
Good luck with the issue
RC
DON KELL
  • 2002 CHEVROLET S-10
  • 4.3L
  • V6
  • 4WD
  • 150,000 MILES
Normal speed runs fine but on acceleration bogs and has no power cuts out a little. Getting no indication from check engine or codes.
AL514
  • 4,105 POSTS
Hello there and thanks for using 2CarPros.com. You should start by running a fuel pressure test, The truck may have some fuel pressure but may be losing fuel volume upon hard acceleration. Start with a fuel test and go from there.
DANO81
  • 4.3L
  • V6
  • 4WD
  • 198,000 MILES
My truck has been giving me problems for a while now. It used to idle really rough and had no power at all. I replaced the catalytic converter and bank 1 sensor 1 O2 sensor. It seemed like it solved the problem. It ran fine for about 2 weeks and now the problem returned. It idles pretty well but has no power when I stab the throttle (won’t go above 2,000 rpm's) it seems to be running rich since I smell fuel. I replaced the TPS, the MAP sensor, MAF sensor. Getting a MAF sensor code (P0101) as well as a engine misfire code. Also just recently got a MIL circuit malfunction code (P0650) and noticed the lights pulse while running. Thinking that’s the alternator going bad. Could the alternator be a cause of this problem? Also replaced fuel pump and filter last year. Did a fuel pressure test and got 55psi right before start up and holds pressure. At idle I get 55psi and when I stab the throttle it jumps to 60psi but stays at 60psi even when engine bogs down. After shut down it goes to 55psi and holds. Is this sensor related, could it be electrical? I’m going to replace the plugs and wires, is that a step in the right direction? Did the cap and rotor last year. Also what about the alternator and the engine light/MIL code? Please help, I’m running out of options here and really would like to stop pouring money into this thing with no results.
  • 108,173 POSTS
The P0650 indicates there is a malfunction in the MIL control circuit. I don't feel that is related to the alternator.
Tell me. You indicated that you smell gas. If your scanner have a live data setting, let me know what the short term fuel trims are. Also, I know you replaced the catalytic converter already. The idea that you smell fuel may be indicating a rich issue and may have already damaged the new converter. Take a look through these links:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Now the link says to remove the converter. If you remove the oxygen sensor upstream from the converter, it will make a difference if the converter is once again plugged.
Also, are you certain there are no major engine vacuum related issues? Here is a link explaining how to check:
_____________________________________________
As far as the P0101, you are correct it is related to the MAF. However, it could be an electrical issue or even a vacuum leak causing a variation between the MAF and the manifold absolute pressure sensor (MAP). Here are directions related to the P0101. They explain the code, possible causes, and the pics attached below are diagnostic flow charts.
2002 Chevy Truck S10/T10 P/U 4WD V6-4.3L VIN W
P0101
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0101
P0101
CIRCUIT DESCRIPTION
The mass air flow (MAF) sensor is an air flow meter that measures the amount of air entering the engine. The powertrain control module (PCM) uses the MAF sensor signal in order to provide the correct fuel delivery for a wide range of engine speeds and loads. A small quantity of air entering the engine indicates a deceleration or idle. A large quantity of air entering the engine indicates an acceleration or high load condition. The MAF sensor has the following circuits:
An ignition 1 voltage circuit
A ground circuit
A signal circuit
The PCM applies a voltage to the sensor on the signal circuit. The sensor uses the voltage in order to produce a frequency based on inlet air flow through the sensor bore. The frequency varies within a range of around 2,000 Hertz at idle to about 10,000 Hertz at maximum engine load. The PCM uses the following sensor inputs in order to calculate a predicted MAF value:
The manifold absolute pressure (MAP)
The intake air temperature (IAT)
The engine speed (RPM)
The PCM compares the actual MAF sensor frequency signal to the predicted MAF value. This comparison will determine if the signal is stuck based on a lack of variation, or is too low or too high for a given operating condition. DTC P0101 sets if the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value.
CONDITIONS FOR RUNNING THE DTC
DTCs P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0121, P0122, P0123, P0335, P0336, P0401, P0440, P0442, P0443, P0446, P0449, P1106, P1107, P1111, P1112, P1121, P1122, and P1441 are not set.
The engine is running.
The ignition 1 signal is between 11-18 volts.
The throttle position (TP) sensor angle is less than 95 percent.
The change in the TP sensor angle is less than 5 percent.
The MAP sensor is less than 80 kPa.
The change in the MAP sensor is less than 3 kPa.
The above conditions are met for 1.5 seconds.
CONDITIONS FOR SETTING THE DTC
The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds.
DIAGNOSTIC AIDS
Inspect for the following conditions:
An incorrectly routed harness. Inspect the harness of the MAF sensor in order to verify that it is not routed too close to the following components:
- The secondary ignition wires or coils
- Any solenoids
- Any relays
- Any motors
The throttle plate for sticking, or for deposits on the throttle plate or in the throttle bore.
A low minimum air rate through the sensor bore may cause this DTC to set at idle or during deceleration. Inspect for any vacuum leaks downstream of the MAF sensor.
A wide open throttle (WOT) acceleration from a stop should cause the MAF sensor g/s display on the scan tool to increase rapidly. This increase should be from 6-12 g/s at idle to 130 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system.
The barometric pressure that is used in order to calculate the predicted mass air flow value is initially based on the MAP sensor at key ON. When the engine is running the MAP sensor value is continually updated near wide open throttle. A skewed MAP sensor will cause the calculated mass air flow value to be inaccurate. The value shown for the MAP sensor display varies with the altitude. With the ignition ON and the engine OFF, 103 kPa is the approximate value near sea level. This value will decrease by approximately 3 kPa for every 305 meters (1,000 feet) of altitude.
A high resistance on the ground circuit of the MAP sensor may cause this DTC to set.
Any loss of vacuum to the MAP sensor may cause this DTC to set.
A high resistance in the ignition voltage circuit of the MAF sensor may cause this DTC to set.
If you suspect the condition may be related to aftermarket accessories, refer to Checking Aftermarket Accessories in Diagnostic Aids.
If the condition is intermittent, refer to Intermittent Conditions. See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Intermittent Conditions
TEST DESCRIPTION
Steps 1-6
pic 1
Steps 7-11
pic 3
The numbers below refer to the step numbers on the diagnostic table.
4. This step will determine if the MAP sensor voltage is within the proper range at idle.
5. This step will determine if the MAP sensor responds properly to the change in manifold pressure.
6. This step will determine if the throttle position (TP) sensor is operating properly.
7. This step will determine if any mechanical faults have caused this DTC to set.
Let me know if any of this helps or if you have other questions.
DILLONBD
  • 6 CYL
  • 4WD
  • 170,000 MILES
Loss of power &acceleration after about fifty miles of highway driving.
Monday, December 14th, 2020 AT 9:09 AM (Merged)
  • 108,173 POSTS
Hi:
Is the check engine light on? It sounds like you have a catalytic converter that is going out or a MAF sensor that is bad but to be sure here are three guides to help us fix it.
and
and
One more question, when it looses power, does the engine studder or feel like it's going to shut down?
WELDER56
  • 2000 CHEVROLET S-10
  • 136,000 MILES
Put on new fuel pump&filter, changed plugs, oil, put tester on codepo340 cam position sensor, put that in about 2 months ago
FIXITMR
  • 9,990 POSTS
TPS check out ok? Does it do it same worse when driving?
WELDER56
IT IS WORSE WHEN IN GEAR
FIXITMR
  • 9,990 POSTS
What about possible vacuum leaks?
FIXITMR
  • 9,990 POSTS
Is light back on? Any new codes?
Monday, December 14th, 2020 AT 9:10 AM (Merged)
WELDER56
NO LIGHTS SAME CODES
WELDER56
A FRIEND SAID IT SOUNDS LIKE TIMING CHAIN
FIXITMR
  • 9,990 POSTS
When those 4 cyl engines arn't running right they can sound like lots of things.
KRFLOY
  • 6 POSTS
2000 Chevy s10, acts like its running out of gas. Total loss of power once the truck is warmed up. Out of ideas. We have already done a complete tune up, replaced the injectors, the o2 censors, the maf censor, and the computer for lack of a better idea. The fuel pump and catalytic converter have been tested and are working fine. Anyone have any other suggestions?
