windows and locks do not work?
2016 CHEVROLET MALIBU
53,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
SAMZXZXZX
No access to vehicle link to pull codes out due to no power to ignition.fuses not blown but didn't jump any relays.Just wondering if relays power the fuse for ignition or blown fuse box?
Jun 23, 2019 at 7:22 PM
  • CAR REPAIR CONTRIBUTOR
If I understand this issue then you are not able to pull codes because the ignition will not turn on? If that is the case, then we need to check power going to the body controller because the way this works, is the BCM just gets the switch button input and it is literally just an open closed switch. So when it is close, the BCM sees 12 volts on the ignition mode switch input and that tells it that someone just pressed the button.
So this means we need to make sure Fuse BCM 6 is not blown. If it is not, then we need to check for voltage on the BCM connector X2 pin 17. This should have 12 volts when you press the button. If it doesn't then you need to replace the ignition mode switch. If it does then there is an issue with the BCM.
Here are some guides that will help with this:
So when the BCM gets the input signal from the button it sends that info to the PCM and tells it to start the engine.
Let's run through this material and find out what we have and we can go from there. Thanks
Feb 8, 2021 at 2:03 PM
CARY DIETSCHE
Installing floor mats on front passenger side of vehicle. Accidentally drilled into the wire harness next to console on front passenger side. Cabin partially filled with smoke. Several wires were affected. All four power door locks quit working. Heater blower fan also quit working. Spliced the affected wires and now the blower motor works on three of the four lower settings but not on high. The dome light in center of head liner also does not work. The remote key will not open door locks, the switches on inside panels of doors will not unlock doors either. When lock and unlock are pressed on the remote you can hear a relay click under the dash. There are no fuses blown in any of the three fuse blocks. Help?
Feb 8, 2021 at 2:04 PM (Merged)
  • 54,354 POSTS
Bummer, I had to hang a picture on the wall put a wood screw right into a water pipe, yep I feel your pain. :) If you fixed the wiring and all fuses are good it sounds like the BCM has blown out here is its location you will need to have it programmed in at a shop it should cost about $130.00 once you have the new one here is the BCM location.
Cheers, Ken
CARY DIETSCHE
Okay, will look into that.
  • 54,354 POSTS
Cheers, Ken
NATJESSE
our malibu brought new....the strangest thing happened the car is in park and i...the passenger tried to get out..and the door would not open...the unlock and lock mechanism works ...meaning the door lever goes up and down when the door lock button is pushed but the door will not let you out? this occurs on the driver side as well!! so we had to crawl out the back doors!!! also ...sometimes the doors will not shut tight...they bounce back open??? any suggestions...we are going to the dealership in a few days to have it looked at....i would also like to mention that this problem doesn't always occur everytime ... thanks
BASSTECH
  • 236 POSTS
G.M. does have a bulletin discussing that issue with the rear doors, but it could still be the same problem with the front doors. they will most likely need new door latches. Let me know how you make out. Here are the door lock wiring diagrams so you can see how the system works. It could be the BCM causing the issue as well. Here is how you replace it. A CAN scan will help tell for sure.
https://youtu.be/InIlnsjOVFA
DIYPATTYJ
Temporary solution to passenger latch not responding to handles (inside and out) but manual locks responding to lock/unlock button: I have an 2008 Malibu LTZ and my passenger door did this. I did some research and what worked, for now, is slapping the door panel a couple of time right above the handle, lol seriously. Can’t get the panel off To fix the latch if the doors shut, am I right? Before the slapping, a suggestion was that the latch is stuck in between lock/unlock and to just lock/unlock the door a bunch with the manual lock. But that wasn’t doing it for me.
My drivers door lock/unlock button isn’t responding, though also,separate issue, I believe.
These issues are most likely the same issue. If the lock button is not responding but the door doesn't unlock or lock then it is most likely caused by a faulty actuator. The slapping of the door panel was getting it to operate then yes, it is sticking. That is not uncommon for these when they begin to fail.
I attached the process and as you can see, you do need the door open so I would suggest you get the door open and then make the repair. If you cannot get the door open then you may have to cut a hole in the panel to unlock it so we don't want to push it with the door not opening.
MABERCROMBIE02
My door lock unlock and lock by themself. We already replaced the computer module that controls the locks. We also have reset the alarm system.
Feb 8, 2021 at 2:05 PM (Merged)
BASSTECH
  • 236 POSTS
Try unplugging the switches one by one and see if it stops. Sometime the switches go bad and the contacts get corroded.
If not, you may have an electrical problem in wiring, first place to look is where the body and door meet.
Sometimes the wiring harness break in there and makes contact with other wires.
EDM7151
4 door. Front passenger door will not open. Car has power locks.
HMAC300
  • 48,601 POSTS
see I f it will open from inside or outside to get it open otherwise door panel will need to come off and see if there are broken clips holding rods on that go to door handles unless lock actuator isn't working but you should be able to unlock form inside. cold be a broken cable going to door latch as well
2CP-ARCHIVES
  • 4,540 POSTS
Door locks acting inconsistent? If I unhook the battery and then reconnect it what trouble could I create?
CARADIODOC
  • 34,309 POSTS
Very happy you asked that before just doing it. Too many people still think there is something that will magically "reset" based on the stories of that working on much older GM cars. I heard of at least one 2008 GM car that everything worked normally on after the battery was disconnected, and that made me happy, but there are way too many stories of various computers locking up requiring a tow to the dealer to have them reprogrammed.
You aren't going to solve an intermittent problem by disconnecting the battery. "Inconsistent" can mean a lot of things, but if the locks work properly some times, the programming in a computer is not the cause of the problem. On Volkswagens, BMWs, and 2002 and newer GM products, I would never suggest disconnecting the battery, but if you're going to try that, I would do it in the dealer's parking lot so you don't need to pay for a tow if it doesn't start after that.
JASENMASE
Both driver and passenger power locks don't seem to work, but whenever I put the car in park they automatically unlock. Do i changed both power lock switches or just the driver side?
Good afternoon,
The locks are controlled by the body control module. The switches send a signal to the module and then the locks will work from the module.
If you have a scan tool, you could monitor the live data in the BCM to see if there is a signal sent from the switches.
If there is, then the BCM is the issue.
If there is no signal, then it is the switches.
PUERTO
At times when locking my doors, certain doors lock and others don't.
I'm not sure if my battery is dying or I have a sensor problem.
Do I reboot my system somehow or do I need to bring it in to a dealership????
Feb 8, 2021 at 2:06 PM (Merged)
  • 110,190 POSTS
If the problem is with the same door all the time, chances are the actuator for the lock is going bad. You need to check to see if 12v of power is going to the affected doors. If it is, then the actuator is most likely the problem.
SATHOMPSON
Automatic door locks will not work with key fob.
  • 54,354 POSTS
It sounds like you have a fuse out or the fob has gone out. I would stat with the fuses.
Here is a guide to get you started:
Below are the fuse locations.
Check out the diagrams (below).
Cheers, Ken
MARY JANE NORMAN
door locks lock and unlock on their own by their self sometimes when I'm driving sometimes when I'm just in the car accident and turned on on the same page to drain my battery. what do I could undo the fuse to make that stop and just unlock my doors manually?
Good morning,
This sounds like the body control module.
When you command lock and unlock, the signal goes to the body control module and then the module commands the locks to work.
When it malfunctions, it does this exact issue.
I would have this checked with a shop to confirm. they need to access the module and watch the commands.
ANDY ANDERSON
My automatic door locks seem to be possesed during the heat and humidity of the summer months. They have a tendency to lock and unlock constantly.( even when the car is turned off and the key is removed. )I have checked all of the fuses and they are all good. Just this week my interior buttons stopped working also.
Canyou help me? I realy can not afford to take it to a dealership.
Feb 8, 2021 at 2:07 PM (Merged)
PELLETIERB
I also have a 2006 chevy malibu and I have the same issue.
ROBERT KEITH
I had the same problem in my volvo. The locks would pop up and down intermittantly and rapidly. The issue may be in the key fob. Try taking it for a drive and leaving the key fob at home. Worth a shot.
JESSE GUN
Got a few steps for ya. 1) pull the panel on the pass floorboard near the center console, disconnect the wiring harnesses and the 30a fuse, install die-electric grease and then re-install, then test lock. if that doesn't work 2)remove driver and passenger door panels {remove corner piece, 2 screws behind door panel handle, & slightly pry panel off from bottom-up} and remove both window switches, & install grease. without re-installing panel, retest lock. if this does not work 3)replace window actuators & window switches. you can buy switches at O'Reilly, but youll have the get the actuators online or at the dealership.
HOMERJ
I have a 2008 chevy malibu that has door locking/unlocking problems. When I press the lock button it only locks the right rear door. Same with the unlock. The problem is the same using the key-fob. Thats today, sometimes this changes where none of the locks work properley.
I was told it is the lock actuator. Is there one on every door? Please help!
CADIEMAN
  • 3,544 POSTS
yes there is.remove the panel.youll see the actuator assys.you may be able to lube the lock linkage with penatrating oil to repair.
