My starter wont crank the engine over?
2005 CHEVROLET MALIBU
10,500 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
CHEYENNE WALLER
It just makes a clicking noise. how do I get it to turn off? it was working fine just last night.
Mar 1, 2020 at 5:32 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Is the clicking coming from the starter? You may just have a dead battery. Try this first. Turn the key to the run position and allow it to stay on for approximately 10 minutes. After that amount of time, the light should turn off and the vehicle should start. If it still doesn't start, check the battery's charge. Here is a link that explains how to load test a battery:
Let me know what you find.
Mar 1, 2020 at 6:04 PM
More then likely the starter solenoid is failing in cold weather like this. I would try and tap on the side of the starter when this happens and see if it turns over a few more times.
If that is the case then here is a guide that will help with replacing it.
https://youtu.be/5Jd2-wfIKOw
Also, here is another guide that will help with this issue if the starter is not the solution:
Lastly if this is happening only when cold, we should load test the battery just to make sure it can carry the proper load.
Let us know what you find. Thanks
Jan 29, 2021 at 3:43 PM
