Mechanics
CHEVY WONT START
1991 Chevrolet Lumina
Engine Performance problem
1991 Chevy Lumina 6 cyl Front Wheel Drive Automatic 109xxx miles
will not start once is hot and has cooled a minute about 140-180 degrees replaced plugs, wires, ignition control module, and crank position sensor also is a loping idle when in the same temp. Range
Srowbotham89
September 5, 2008.
Check for spark (even though you replaced some parts, you may still have no sparks). Are your spark plugs wet?
Check for fuel
Check compression
If they all test okay, you could also have a bad coolant sensor preventing your car from going into closed loop.
I would check for DTCs.
RenaudTN
Sep 5, 2008.
AD
