blower motor not working
2006 CHEVROLET EQUINOX
145,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
GARICAN1
Hello, blower motor will not operate in any speed setting i have checked all my fuses along with all the blower relays and the switches.All check out good i did find a shorted connection on the blower resistor harness i went and purchased a new resistor and harness.When i was done putting it all back together i still didnt get any results.What else can i check now?
Mar 6, 2014 at 7:38 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
this sounds like you have a blower motor that is not working but to be sure this guide will help you see whats going on.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here is the blower motor location as well. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Mar 6, 2014 at 8:01 AM
GARICAN1
Thanks it was the blower motor I got a new one for 89.00 all fixed ! I love this site.
Mar 6, 2014 at 12:33 PM
JBOHREN
Blower fan does not work. If you hit a bump or slam the passenger door the fan may go on for a short while.
Also looked at the blower under dash. Where is the blower resistor?
Jim
Jun 20, 2019 at 5:21 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Jim, Thanks for the Donation. The Resistor is hiding behind the blower motor.... You can use your CTRL and "+" to zoom in to read better..
https://images.2carpros.com/forum/automotive_pictures/188069_05equinoxblowerresistor_1.jpg
JBOHREN
Engine is a 6 cylininder.
Blower does not work. Is it typicaly the resitor that is the problem? Is the resistor detached from the blower.
Jim is a
OBXAUTOMEDIC
  • 3,711 POSTS
You stated in your original post that
"Blower fan does not work. If you hit a bump or slam the passenger door the fan may go on for a short while."
I t could be the Resistor or just a loose connection on the blower motor or the resistor.
KENDRAB
I have a 2006 Chevy Equinox. The blower for the heat/ac is not working. The actual heat and ac are working there is just nothing blowing it out. Is this something that can be repaired inexpensively? Does this require taking my car to the dealer for repair? What should or could I check myself before taking it somewhere?
Jun 21, 2019 at 1:58 PM (Merged)
  • 54,354 POSTS
It sounds like you have a blower motor that is out but to be sure we need to check for power at the blower. Here is a guide that will give you an idea on how to check for the problem. There is also a blower motor relay that you can check as well.
and
and
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
