AirBag Light on
2007 CHEVROLET EQUINOX
BRANDONB1
  • 8 POSTS
how do you change a passenger seat sensor? The airbag light is on and i got it scanned and i got this code B0074?
Sep 13, 2012 at 8:17 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
This is how you gather the codes for an airbag in case anyone reading this whats to know.
https://youtu.be/gnSGfEqrf_w
The code you have is for the passengers side weight sensor problem. I would check the fuses first and then check the wiring to confirm the failure. Here are guides to help you see what I'm talking about. The codes will clear themselves once the problem is fixed
and
Check out the diagrams (Below) Please let us know what you find.
Sep 13, 2012 at 8:19 PM
BRANDONB1
  • 8 POSTS
When I scanned it dealer they gave my this code B0074 And they told me it was a sensor on the passenger side, So Should I check for a loose wire or check the fuse? What should I do next?
Sep 13, 2012 at 8:27 PM
SATURNTECH9
  • 30,869 POSTS
I would first check for a wire issue and also unplug the sensor and. See if the terminals are loose or open. If everything looks okay replace the sensor.
and
Please run this test and get back to us.
Cheers, Ken
Sep 13, 2012 at 8:59 PM
BRANDONB1
  • 8 POSTS
Yep that was it someone had disconnect the sensor from the seat once I fixed it the light went out.
Thanks guys!
Sep 13, 2012 at 9:06 PM
SATURNTECH9
  • 30,869 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
Sep 13, 2012 at 10:58 PM
SMYERS6026
My airbag light one day just came on and has been on ever since?
Dec 10, 2019 at 12:09 PM (Merged)
DOCHAGERTY
  • 9,606 POSTS
There is a fault in the supplemental restraint system and it will require the problem to be identified and corrected before that light will go out. Here is a video that will show you how.
https://youtu.be/VflcXgWKhqw
DWAINWEARY
the clock spring behind the steering wheel it was tough but I did it cost me $143.00 for the part.
SUMMJE
What wires make contact when you seat in seat?
Nov 19, 2020 at 9:44 AM
STEVE W.
  • 15,158 POSTS
On a 2007 Equinox, the wires go to the seat sensor. It isn't just a switch it actually sends the passengers weight information to the system to tell it if there is a person in the seat and how hard it should deploy the airbags to handle that weight. There are 4 wires to the module. One is Red with a white stripe, that is battery power, another is Black with a white stripe and that is the ground. The two green wires are the data lines to the SRS module that tells it how much the person in the seat weighs.
Now if you have the 2005 version there is no sensor.
Nov 21, 2020 at 1:12 AM
