2CarPros - Car Questions & Answers
2004 Chevrolet Colorado Repair Question
Topics covered: Blower motor, Terminal, Body.
Asked on July 26, 2008
Chevy blower motor
Air Conditioning problem
2004 Chevy Colorado 6 cyl Two Wheel Drive Manual 77000 miles
I have a 2004 Chevy Colorado and the air condition started only blowing on high about a month ago settings 1 2 and 3 would blow intermittent at first than stopped blowing all together. Today it stopped blowing on high as well setting 4. What could be the problem. The AC compressor is coming on, but no air is blowing through the vents. Could this be a relay problem or a blower motor resistor malfuntion? Please advise.
Mike~
Avatar Asked by MikeCAM
Answer
Replied on July 26, 2008
it is a blower resistor.here is a bulletin with part numbers.Subject: Blower Motor Inoperative In Any One or More Blower Speed
Models: 2004-2006 Chevrolet Colorado
2004-2006 GMC Canyon Blower motor inoperative in one or more blower speeds. This concern is due to a loose connection at the blower motor resistor.
Recommendation/Instructions:
Inspect the connection at the blower motor resistor. Replace the blower motor resistor and any terminals in the female part of the connector that show evidence of arching or corrosion. The replacement connector and terminals are listed below.
Part Number 15306069, Female Connector With Leads. Replace the connector body with leads only if the connector body shows signs of damage. It may be necessary to generate a SPAC case to obtain this connector with leads.
Part Number 12176387, Replacement Female Terminal. This terminal is made of copper-beryllium and can be located in Delphi tray 3 of your Packard kit. Only replace the terminal(s) if the connector body has no evidence of damage.
Replace the blower motor resistor only if it shows signs of arching or corrosion at its terminals.
post back with the results.
Tiny Answered by brian 1 (expert)
1,100 answers provided
