wiring diagram to starter
1999 CHEVROLET CAVALIER
156,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
GEOHART01
I have 5 wires to connect to solenoid and a thin black wire broke and I'm having problems connecting the wires I have 3 with big eyelets one small red wire with small eyelet can some one please direct me as to hook up all 5 wires correctly
Oct 19, 2014 at 1:46 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,346 POSTS
Here is a guide to show you how the wires go and how to test the starter with the wiring diagrams below
The 2 large eyelets go to the upper large lug, the one small wire will go to the smaller eyelet on the right side of the solenoid if you are looking right at it, here is a diagram to help. The image below shows how they go, the small black wire does not go to the starter.
Nov 8, 2017 at 3:55 PM
JDL
  • 16,098 POSTS
Welcome to the forum. Don't let the starter fall and hit you. On the flywheel end, if there is a longer bolt, it goes to the inside.
https://images.2carpros.com/forum/automotive_pictures/170934_cavalier_starter_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_cavalier_starter_2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_no_3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_no_4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_no_5_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_no_6_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_no_7_1.jpg
Nov 8, 2017 at 3:56 PM (Merged)
MCKENZIEA
Electrical problem
1997 Chevy Cavalier Automatic
My starter wouldn't turn over this morning. This has happened before. The starter is practically brand new but the wires aren't and every now and then there is one wire that comes loose. However, my dad isn't here to fix it this time. Do you know what wire it is that I would need to push back in and where the starter even is in my car because I don't really know anything about cars.
Jan 23, 2019 at 1:47 PM (Merged)
Hi mckenziea, Welcome to 2carpros
The wire you looking for is the purple wire at the starter motor solenoid and its not a push on connector-it has a nut on it, you might try tightening it-
The starter is located at lower front of engine-Best way to find it is follow the battery positive cable towards the engine it will take you straight to it. Sorry no pic
GREGPHILB0
I have a 2.2 liter engine in a 96 Cavalier. Bought a starter and forgot to label all the wires (I Know ..... Stupid me) Could you please help me in putting this back together. Starter is an After market bought at Auto Zone. Thank you so much Greg
MMPRINCE4000
  • 8,548 POSTS
There is a large wire that bolts or plugs in to the starter, and a smaller one that bolts or plugs in to the solenoid. Ground is provided by bolting to block.
The large wire should be red in color. This will go to the larger stud on the solenoid. Then the smaller wire will go to the smaller stud on the solenoid.
Pictures are attached below. Thanks
SSJRT
  • 5 POSTS
there is a set of small wires going to the starter and 1 of them has broken off and the car wont turn over. there looks to be a red wire and a black wire, and that is the one that is broke, to witch post on the starter does it go to
SSJRT
  • 5 POSTS
there was a recall on the car and when i went to have it done they put what looks like a fuse and the wires coming out of it is what broke just not sure if it goes to where the negitave battery cable go to or to the smaller post on the starter
BMRFIXIT
  • 19,053 POSTS
[quote:1a834a09d8="SSJRT"]there was a recall on the car and when i went to have it done they put what looks like a fuse and the wires coming out of it is what broke just not sure if it goes to where the negitave battery cable go to or to the smaller post on the starter[/quote:1a834a09d8]i would say it goes on the big bolt of the starter it has battery power all time
SSJRT
  • 5 POSTS
thanks i will give it a try
GUSS101
I have a 1998 Chevy Cavalier that was sitting unused for about 3 months. It wouldn't start, so I replaced the starter in it, and the battery later. It still won't turn over even though the wiring is all connected and the fuses are okay. How can I fix this issue without going to a mechanic? Or is that the only option...
BMRFIXIT
  • 19,053 POSTS
[quote:8fd1d1fd30="SSJRT"]DEALERS WILL INSTALL A RELAY KIT IN THESE VEHICLES TO PREVENT HIGH CURRENT FROM FLOWING THROUGH THE IGNITION SWITCH, AND CHECK THAT YOUR CAR WILL START WITH A PROPERLY CHARGED BATTERY AND, IF NECESSARY, REPLACE THE IGNITION SWITCH
this is the recall and the wires coming out of the relay 1 of them is broke does any1 know where all the wires connect to on the starter[/quote:8fd1d1fd30]
give me the color of that wire
now i know what your looking for
red wire butts with the purple wire
WRENCHTECH
  • 20,761 POSTS
Do you have a security light on or flashing when you try to start it?
SSJRT
  • 5 POSTS
it is the black wire that is broke
GUSS101
The Theft System light turns on the dashboard when the key is put in.
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_starter_1.jpg
WRENCHTECH
  • 20,761 POSTS
Try the 30 minute relearn sequence.
30 Minute Re-Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlock™ Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if desired (history DTCs will self clear after 100 ignition cycles).
SSJRT
  • 5 POSTS
it is a black wire coming out of the relay and it goes to where the positive battery cable goes to. i found the broken wire connecter on that post of the starter.
thanks for all of ur hlep
GUSS101
I waited twenty minutes following your instructions and the THEFT SYSTEM light never turned itself off. I went thru the process regardless , turning it off after about 10 minutes 3 times to no avail.
One other odd thing, about 30 seconds after I turned the key to 'start' I heard a low grinding sound from the engine and the LOW TRAC light came on briefly. I doubt this is issue is connected but I felt it odd enough to mention.
WRENCHTECH
  • 20,761 POSTS
Then you have more serious issues with the security system that need to be addressed and you will need a Tech2 scan tool to do that.
GUSS101
Alright, thank you for your assistance, I will get it to a mechainc.
DEWEYSCAR
I put in a starter and now my vehicle wants to keep starting itself, even without the key, I need some guidance on the wiring
Check the starter motor solenoid-could be shorting out internally
DEWEYSCAR
The shop where I bought the starter tested it to see if it was faulty, it tested fine...
Okay-time to check the ignition switch
DEWEYSCAR
thanks, I'll get on that tomorrow... thanks for your help!
REBECCA47
I am a single Mom, with no money. My car wouldn't start today. My neighbor said it was something with the starter, maybe a short in the wiring. I can start it by turning the key to On and using a screwdriver between two bolts on the selinoid. From what I can see there isn't a short, but alot of the wiring is covered. I know if I take it somewhere they will tell me I need a starter. Do you have any ideas I can do? I am kinda good fixing stuff. I have done alot of research today online.
Next step is to inspect and test the park and neutral switch and ignition switch
KENTHEWOOD1021
Electrical problem
1997 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
ok my g/fs dad replaced the starter in her car and somewhere i guess he forgot what wire goes were and hooked it up wrong so if there is anyone who could tell me directions on how to figure out how to hook it up or has a diagram i would apriceate it thanks
RHALL77
  • 3,361 POSTS
what wire does he have a question on. the small terminal goes to the small post.
NORBERT BOND
how to change a starter on a 2000 cavelier
Jun 24, 2019 at 6:39 PM (Merged)
REMOVAL PROCEDURE
Disconnect the negative battery cable.
Remove wiring harness bracket nut from starter bolt.
Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove flywheel inspection shield.
Remove the electrical connections from starter.
Remove the starter bolts and starter.
DAVBOZ7
Hi. Maybe you can help..Have a starting issue with 1996 Chev Cavalier. Charging/battery are fine. Had initial clinking clunking, jiggled connections, got it started once to get home, now nothing. Full power, but no activity to starter(solenoid?)
So, went back to hand-checking connections. One supplemental(?) wire to main solenoid terminal bent and snapped at it's connecting ring.
There are FIVE wires in total connecting to solenoid.
THREE go to main post which includes POS battery connection, a black one coming from a very large fat bundle, and a mystery wire which broke at the eyelet.
The broken "mystery wire" comes out of a smaller bundle, as do the remaining TWO wires to the solenoid - each of those TWO going to the other two individual terminals on the solenoid.
The "mystery wire" seems not to be easily spliced or reconnected.
I had hoped maybe this was the cause of not getting a signal to the starter. Now, I'm wondering, is it an essential component, and how might I establish a connection here. It seems like something like fiber-optic, although I doubt that. It just isn't your common wire.
Any ideas?
Thanks for being available!!
CARADIODOC
  • 34,309 POSTS
The purple wire, (purple arrow), goes to the smaller "S" terminal on the solenoid, (blue arrow). That is always the only wire that goes there. That is the one that activates the solenoid when it gets 12 volts from the starter relay, or in some cases, directly from the ignition switch.
The other small terminal "R", (yellow arrow), when used, is as a relay terminal. It gets 12 volts put on it during cranking, to bypass the ignition resistor for stronger spark and easier starting. That terminal is used on older cars and may not even exist on newer solenoids.
The red arrow is pointing to the generator's output wire. The red part of the wire is a spliced-in fuse link wire. It is slightly smaller in diameter so it's the weak link in the chain. Also, its insulation is designed to not melt or burn when the wire burns open. This wire goes directly back to the battery's positive post, but GM likes to use the larger stud on the solenoid, (orange arrow), as a convenient tie point since the battery cable also goes right back to the battery. No point in running two wires when they both go to the same place.
I suspect you're referring to the black wire by the green arrow. That is not shown as part of the starter circuit, but it is typically another circuit the uses the large terminal as a tie point, rather than running back to the battery. The arrow is pointing to a piece of heat-shrink tubing that covers a splice. That indicates it is the starting point for another piece of fuse link wire. This wire will feed multiple other circuits to potentially include exterior lights and horn, as well as the ignition / starter switch. With this wire broken off, you should find multiple systems, including the starter system, are dead.
This is a relatively simple repair, but you must be careful to never touch a metal tool to the large battery terminal, (orange arrow), and another metal part on the car, at the same time. That would create huge sparks and could weld the tool in place and cause it to become red-hot and melt. It is safer to disconnect the battery's negative cable, then continue with the repair.
Strip the end of the wire, then crimp on a new terminal, and bolt it onto the stud. You'll probably have to buy a small box of terminals from an auto parts store. The crimp end has to be small enough to crimp effectively around the wire, but the ring end has to be large enough in diameter to fit over the stud. That combination of sizes makes it an uncommon terminal that you may not find in a hardware store.
I prefer to solder the wire to the terminal after I crimp it. Due to the wet location, I pull the plastic cover off the crimp end, slide a piece of heat-shrink tubing onto the wire, crimp, then solder the terminal to the wire, then slide the tubing down and warm it to seal the connection. You can buy heat-shrink tubing with hot-melt glue inside. That will form a moisture-proof seal. The tubing and the glue strengthen the wire to reduce the chance of it breaking again.
You'll need to remove the large nut, then remove and discard the old terminal. Place the new terminal on the stud, then reinstall the nut.
DAVBOZ7
Okay, that is helpful. Now, I still wonder about the extra insulation covering an inch or so at the connecting end as well. When I snipped off a 1/16in. piece to see what it consisted of inside I saw strange stuff that looked like wood, paper, I guess part of the insulation, but could hardly even recognize that there was any wire in there. Do you think I can trust that is a thin wire, that I can successfully expose enough to crimp in a new eyelet, and just try as carefully as possible to strip it?
CARADIODOC
  • 34,309 POSTS
I'm not sure what you're seeing. That has to be a normal wire. Its going to carry a good 8 to 10 amps. The extra insulation you referred to is an old piece of heat-shrink tubing. Cut that all off with a razor blade. It will have that hot-melt glue on it too, so it's going to take some work to peel it off. If you have an extra inch or two of wire, just cut the last part off with the heat-shrink tubing. There's nothing special about it. You just need to be sure when you're done the wire will be long enough to reach to the stud.
