Radiator leak
BRADLEY_P
  • 2008 CHEVROLET AVEO
  • 4 CYL
  • FWD
  • MANUAL
  • 40,000 MILES
ARGH! My father always said "pay less, get less". And with my 2008 Chevy Aveo, that is the TRUTH. I have 40385 miles on my Chevy Aveo when I notice the temp is warm, but there is no heat. I add coolant and determine that the radiator is leaking. I pull out the radiator only to find that the vertical passenger side of the fan shroud was pressed up against the radiator causing it to rub through after 40K miles (just out of the 36K warentee period, way to go GM, you timed that just right). Has anyone else seen this same failure? I am hoping I can get this radiator repaired. I used the dremel to rework the fan shroud so it no longer rubs the radiator. (FYI, GM, this is called "clearance". You all should think about doing a tolerance stackup in the future) I'd say "I'll never buy a GM product again". But, come on. I paid 4500 for this car, what do you expect?
Thursday, February 11th, 2010 AT 9:48 PM
  • 31,937 POSTS
Hi there,
you father is a wise man.... but even a wise may can't see short falls in these design faults, your clearance should fix the problem, good luck with this.
This guide can help
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
mark (mhpautos)
Friday, February 12th, 2010 AT 3:25 AM
MOYER1JE
I have a 2008 Aveo and just rolled over to 40,000 miles. Check engine light came on and engine running hot. There was virtually NO coolant in the reservoir and I had an oil change where they supposedly checked it 50 miles prior to this happening. I cannot see any visible leaks though. And after a week I was down about another pint of coolant. Any suggestions?
Tuesday, September 13th, 2011 AT 3:30 AM
STONEHEAD
  • 2007 CHEVROLET AVEO
  • 4 CYL
  • FWD
  • MANUAL
  • 41,000 MILES
Is it easy to home replace the radiator or should I have it done by a pro? No air conditioning.
Tuesday, October 29th, 2019 AT 5:44 PM (Merged)
BRADLEY_P
It took me 30mins to make enough space to get the car in the garage and 30 mins to drain the coolant and get the radiator out.
- Drain the coolant (It has a drain plug. Standing in front of the car looking into the engine bay--look to your left and straight down below the top radiator hose. Look along side the radiator; near the bottom on the side is a black plastic plug that is hex shaped (approx. 12 mm) with a cross slot in the head of the hex.
If you put a light near the top radiator hose shining down, you can see the plug when looking thru the lower horizontal slot in the front fascia.)
- remove 2 nuts and 1 bolts to loosen up the powersteering resevoir. This thing is totally in the wrong place for this job and complicates the whole thing.
- there is a hose that goes from the resevoir down to a pipe. This pipe is affixed to the front of the car with a pclip and nut. Remove the nut so you can move the resevoir a little better.
- remove the fan shroud (2 bolts at the top of the radiator, disconnect the electrical connector to the fan, then pull out, The bottom passenger side is held in by a clip. I had to pull pretty hard to get it un stuck.
- disconnect 3 hoses (upper, lower, and a small degas hose?)
- remove the two mounting bolts at the top of the radiator
- at this point I was able to wiggle it out of there by lifting the passenger side up and dropping the drivers side down until it had rotated about 90 degrees. Again, the powersteering fluid resevoir was RIGHT in the way and made taking it out a big pain in the butt. You might take out the battery and see if that gives you more room to push the resevior back.
- the vertical passenger side of the fan shroud had rubbed through the radiator. I used the dremel cut enough of the fan shroud away so that it will not rub through on the new radiator. I am going to take it to a radiator shop today and see if they can just fix it so I don't have to buy a new one.
Let me know how it goes for you.
