2CarPros - Car Questions & Answers
2002 Chevrolet Avalanche Repair Question
Topics covered: Battery, Corrosion, Starter.
Asked on January 3, 2008
2002 Chevy Avalanche Starting problems 2002 Chevy Avalanche
I have owned my truck for 2 years and it has always started very slow as if the battery was not powerful enough. Yesterday was a very cold day in Ohio and my truck finally did not start. I took the old battery out had it tested and indeed it was bad but was the correct size battery for my Avalanche. I replaced the battery with a brand new optimus battery with 730 CA which cost me $160 dollars. Even after the new battery is starts very slow. This morning I had enough power to unlock my doors but not to start. I tried to jump my truck but did not have any luck. I put the brand new battery on a charger and it was down to 75% charge. Do you think I have an electrical problem or a starter problem?
Avatar Asked by mmtaylor44
Answer
Replied on January 10, 2008
Check your battery cable ends. Make sure there is no corrosion. This is the most common problem I see.
Tiny Answered by dennyp (expert)
1,879 answers provided
It took a week for you to tell me to check for corrosion. Nice website. Well, a week ago I changed my starter/solenoid and that was the problem. The solenoid had a slight crack in the casing. Thanks for all the help, I'm sure I will return next time.
Tiny Response from mmtaylor44
1 question asked
