Fuel filter
2007 CADILLAC CTS
GANDERS_CHICK
Where is the fuel filter located and what is the process to replace it?
Dec 21, 2009 at 8:21 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
It is located below the rear passenger door, just inside the frame (3.6L ). Here is a guide to help you
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Dec 21, 2009 at 8:34 PM
BOKNOWS
do you have to have a special wrench?
Apr 1, 2019 at 12:42 PM (Merged)
  • 54,350 POSTS
Relieve the fuel system pressure. Refer to Fuel Pressure Relief .
Fig 1: View Of Fuel Filter And Quick-Connect Fittings
Raise the vehicle. Refer to Lifting and Jacking the Vehicle .
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Remove the rear suspension bracket. Refer to Rear Suspension Bracket Replacement .
Disconnect the quick-connect fittings (3 and 4) at the fuel filter inlet. Refer to Metal Collar Quick Connect
https://youtu.be/Boi0DPXVHbM this is for a ford but the process is the same
Fitting Service or Plastic Collar Quick Connect Fitting Service .
Disconnect the threaded fitting (1) at the fuel filter outlet.
Drain any remaining fuel into an approved gasoline container.
Remove the fuel filter (2).
Remove the fuel pipe O-ring.
Discard the fuel filter into an approved container.
Installation Procedure
Remove the protective caps from the new fuel filter.
If originally equipped, install new plastic connector retainers on the fuel filter inlets. Install the new retainers in the same position as on the old fuel filter.
Lubricate the new fuel pipe O-ring with clean engine oil.
Install the fuel pipe O-ring.
Slide the fuel filter into place.
Connect the quick-connect fittings (3 and 4) to the inlet side of the filter. Refer to Metal Collar Quick Connect Fitting Service or Plastic Collar Quick Connect Fitting Service .
NOTE: Refer to Fastener Notice .
Connect the threaded fitting to the fuel filter outlet. Use a back-up wrench in order to prevent the fuel filter from turning.
Tighten: Tighten the fuel filter outlet fitting to 30 N.m (22 lb ft).
Install the rear suspension bracket. Refer to Rear Suspension Bracket Replacement .
Lower the vehicle.
Ensure that the fuel tank filler cap is installed correctly.
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Perform the following procedure in order to inspect for leaks:
Turn ON the ignition, with the engine OFF for 2 seconds.
Turn OFF the ignition for 10 seconds.
Turn ON the ignition, with the engine OFF.
Inspect for fuel leaks.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
LEENEWMAN
How do you get the two small hoses to release from the filter?
FACTORYJACK
  • 4,159 POSTS
There is a special tool(s) that release the fuel line quick-connects. It can be either one tool with both line sizes, or two seperate tools
