Mechanics
BUICK ROADMASTER SPARK PROBLEM
1993 Buick Roadmaster
Engine Mechanical problem
1993 Buick Roadmaster V8 Two Wheel Drive Automatic 130000 miles
just replaced coil, rotor, module, cap and wires and my 93 roadmaster engine died. Before it stop running I noticed that the voltage meter would drop from 15 to 13 on the meter. But everything worked
Cityilu5
May 31, 2010.
Does it try to crank over at all or getting nothing from turning key?
Bluelightnin6
May 31, 2010.
Yes it turns over but will not crank
Cityilu5
Jun 1, 2010.
Will have to test the fuel pressure to see if getting proper fuel and make sure spark plugs are getting healthy blue spark
The fuel pump is working properly. What's next?
Cityilu5
Jun 1, 2010.
Plugs getting good spark? If so then test compression at cylinders.
AD
AD
