air conditioner not working
2011 FORD FUSION
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
PIKESTOG01
My battery died so I charged it with a battery charger enough to crank the car. I then took it to an automotive shop to have them switch out the battery. When I picked it up the air conditioner compressor will turn on and then turn off after a few seconds. Please Help!!! It is full of Freon.
Dec 2, 2013 at 5:58 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Is the AC or the defroster on? It sounds like the fuse popped due to a voltage surge. Here is a guide to help check with the fuse locations below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Dec 2, 2013 at 6:00 PM
PIKESTOG01
Yes. I am trying to use the A/C but the compressor is not staying engaged. It was working fine before the battery was changed.
Dec 2, 2013 at 6:35 PM
CJ MEDEVAC
  • 11,004 POSTS
try removing the negative post for a few minutes, then putting it back on
sometimes the computer on some vehicles senses the low voltage and goes haywire, only the disconnection of the battery will let it reset and recognize the correct voltage of a new/ or recharged battery
other than that, it has the symptoms of being low on gas.....check with a set of gauges....not by just putting more in!
what "j and n" was getting at....not only does the a/c call for the clutch to engage.....any defrost setting will make it come on as well (the evaporator removes moisture from the air before it is blasted onto the windshield)
the medic
Dec 2, 2013 at 6:45 PM
PIKESTOG01
The Automotive shop changed the battery. Then I looked at fuse # 25 10 amp fuse blown so I replaced it everything works great!
Dec 2, 2013 at 6:48 PM
  • 110,190 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Dec 3, 2013 at 5:22 AM
BIGDADDY1963
blower wont run. I have replaced the blower and the pigtail that goes to the resistor. they where burned on one side. the only thing that I haven't replaced is the resistor itself. I also have checked the fuses inside and in the engine. also replaced the relay there too.
Oct 2, 2019 at 10:05 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
You need to test at the motor to determine whether it's power or ground that is missing.and we can go from there.
ROSENDODELEONJR
ac shuts on and off ,had a small fender bender car was fixed compressor was repaied but ac still shuts on and off cold air comes out mildly but bloer not kicking in afetr a week.
HMAC300
  • 48,601 POSTS
This may be due to accident and not being filled up properly or is a condition called freeze up.
This guide can help
Oct 2, 2019 at 10:06 AM (Merged)
BLHOOVER86
I have the above car and the AC was working fine. I turned it on the other day and nothing happened. I determined that the compressor is not engaging. I had someone check the system for Freon and the pressure is good. The AC had been cooling great. I checked the fuse in the car and up in the engine compartment. From what I read, it sounds like it could be the Evap temp sensor that is the problem. Is there a way to bypass the relay in the engine compartment to make sure that it's not a compressor or clutch. There are 5 connections on the relay, which 2 do I "jump" to trick the compressor? If it is the temp sensor, is there anyway to replace it without removing the whole dash assy? Any advisce would be appreciated.
Oct 2, 2019 at 10:07 AM (Merged)
CARADIODOC
  • 34,309 POSTS
Hi blhoover86. Welcome to the forum. It's not the temperature sensor. You would have greatly different symptoms if it was out of calibration.
The easiest way to bypass the relay is to pop its cover off, reinstall it, and squeeze the contact. To jump the terminals, (I'm assuming you have standard relays; I don't have a car here to peek at), if you have the normal 1" square relays, there are two terminals on the sides that are parallel to each other. Disregard those. Also disregard the center terminal. That leaves you with two terminals that form the letter "T". Those are the two to connect.
If you have the smaller 1" x 3/4" relays, there will be three terminals on one end that are parallel to each other. Use the middle one of those three and disregard the outer two. Also disregard the one in the middle and use the remaining one on the other end.
caradiodoc
BLHOOVER86
I have the smaller relays. I took out the relay and tried to jump the ones you suggested (middle one of the three parallel and the one fartherest away). There are not any connectors in the middle of the 3 parallel ones. I quickly tested each one and found that 3 and 4 (the 2 parallel ones) were the ones that would bypass the relay and force the compressor to run. It seemed to run although a little labored. I only left it connected for about 2 minutes to verify the car was starting to cool, which it was. In that short of time, there was a valve or something that seemed to blow to release pressure. I don't know what it was, I only know that it emptied out my radiator overflow tank. It happened somewhere around the shift mechanism on the transmission. I put water back in the overflow, started the car and it ran fine. NO LEAKS. AC compressor still will not run. I wasn't brave enough to try to "jump" it again. Any suggestions? What symptoms would I have if the Evaporator Temperature Sensor was not working? From what I have read, that seems to be a problem with this car. I did notice that my check engine light is on after leaving the battery disconnected for about 20 minutes. Heading off to see someone who has the computer to read the error code. Might shed more light on this. Any input you have will be greatly appreciated.
CARADIODOC
  • 34,309 POSTS
A malfunctioning temperature sensor will affect how much refrigerant is allowed into the evaporator. If too little enters, there will be insufficient cooling. Too much and the evaporator will go below 32 degrees at which point the condensation will freeze and block air flow. You would experience great cooling for a few minutes, then a loss of air flow until the ice melted.
Now, that's how MOST cars work. In yours, they might be using the sensor to cycle the compressor on and off via a computer. Lord knows every former simple, trouble-free system on today's cars has a miserable computer added to it. I'm not aware of any common, or pattern failures with the sensor but that doesn't mean it isn't possible.
Just out of curiosity, have you noticed if the electric radiator fan runs at times? If it does not run in slow traffic after the engine is warmed up, that could be related to the compressor not turning on.
caradiodoc
BLHOOVER86
Fan works fine. I found out that that is was antifreeze coming out of the overflow when the pressure built up after I jumped the relay. The compressor works. Something, relay or sensor is keeping the compressor from engagine. Are there any relays or fuses or sensors (in the engine compartment) that can be checked. I checked the fuses and relays that were obvious in the owner manual, but I didn't know if there were any that would also keep the AC compressor from not coming on.
CARADIODOC
  • 34,309 POSTS
If the refrigerant charge is low, the low pressure cutout switch will prevent the compressor from turning on. That is done to prevent the low side from getting sucked into a vacuum and potentially drawing in outside air through the leak and bringing in the harmful moisture, (humidity) with it. That switch is somewhere between the condenser in front of the radiator and the expansion valve by the firewall. You can jump that two-wire connector with a piece of wire. If the compressor turns on, the system should be checked for leaks and recharged.
Some systems are no longer using the low pressure cutout switch. Instead, they use a single pressure sensor to monitor system operation. I haven't worked on any of those systems.
caradiodoc
JWAD43
recently a/c isn't blowing cold air. have normally ran on max a/c. fan still works, just no cold air. any ideas?
DOCFIXIT
  • 18,828 POSTS
Hook up a guage set and see if charge is low
JWAD43
already did, but it showed it was charged enough. 2nd problem now is I was checking fuses and relays and now the fan doesn't work at all. I may have blown another fuse or something. Haven't had a chance to check things as of yet.
DOCFIXIT
  • 18,828 POSTS
Is system Auto or Manual? Fan out blower or cooling? does AC copm engage? all modes function ie. def,panel? Engine fuse box check fuse #4 & # 29
ECONNOR03
Air Conditioning problem
2007 Ford Fusion 4 cyl Front Wheel Drive Automatic
I am not sure what to do my heat work just fine in my car. There is nothing wrong with my system for the air conditioning thats been check. But it still doesn't blow cold air just hot.
Oct 2, 2019 at 10:08 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
Well obviously, there is a problem with the A/C system if your getting warm air. the problem may be in the temperature controls.
The temp in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
ECONNOR03
Last year I replaced a switch. Is that what you are talking about. And is it possible to show me a image of where to locate this part of the ford fusion. Do it have anything to do with a sensor under the dashboard?
WRENCHTECH
  • 20,761 POSTS
https://images.2carpros.com/forum/automotive_pictures/561653_Blend_door_actuator_07_Focus_1.jpg
The LH temperature blend door actuator can be accessed from below the LH side of the instrument panel.
ECONNOR03
Thank you I will try and update you!
PAUL_D
my ac has completely stopped working, all dash lights are on but no air
WBE31705
mine quit working too... it will blow but the compressor will not engage. ford told me it was an ambient air temperature sensor. when i researched it it show 3 diff air temperature sensors: 1 behind the dash just below steering wheel to the right, 1 in the actual vent/blower assembly, and 1 under the hood mounted on the upper radiator mount.
84BRONCO
  • 6 POSTS
My AC started blowing cold then blowing warm then cool then warm....then it just started blowing nothing but warm. A friend check to see if it was low on freon said that was fine. I check fuses i could find for AC but they were ok what else hopefully not compressor right???
Oct 2, 2019 at 10:09 AM (Merged)
  • 110,190 POSTS
This is what happens when the temperature blend door actuator goes bad. Here is a guide to help walk you through the steps and the location of the actuator for you car below.
KENDRICKL
I have discharge the A/C system and pull a vacuum 30 mc but when recharging the Freon it just goes up on pressure and nothing is cooling. while all the buttons and fuses and blower work, just no cold air.
Jun 25, 2020 at 4:58 PM (Merged)
Do you happen to have a gauge set that can give you the low and high side pressures? That is good that we know there are no leaks due to it holding a vacuum but we need to find out if the system is full.
I assume it is full and if the compressor is running but no cold air then the compressor has failed. However, let's start with the pressures because it may just be low. The pressures will tell us if the compressor is creating the pressure difference that is needed and we will quickly find out if the compressor is faulty. Thanks
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
