Engine misfiring
CINCYDEB
  • 2006 ACURA TL
  • 3.2L
  • 6 CYL
  • FWD
  • 145,000 MILES
The check engine light on my car came on, and the codes were that three cylinders were misfiring. My husband replaced the spark plugs, coils and fuel injectors (not all at the same time, over a couple months when one did not solve the problem).
None of that has solved the problem. The car idles rough on startup, will sometimes smooth out and drive fine, but other times you can feel it "buck" or "thump" at a stop light and it hesitates on acceleration.
What else could be causing the problem? The check engine light is still on and it still gives the same codes.
Monday, July 6th, 2015 AT 10:37 AM
WRENCHTECH
  • 20,758 POSTS
This happens when the MAP sensor gets a little off but not enough to trigger a light. Here is a diagram below so you can perform the replacement.
Please check out this guide
Monday, July 6th, 2015 AT 10:57 AM
RKAUSTIN
Thanks you so much! I did this and it worked perfect for my car never ran better. I love this site. :)
Monday, July 2nd, 2018 AT 4:36 PM
REY LEMUS
  • 2003 ACURA TL
  • 3.2L
  • 6 CYL
  • FWD
  • 200,650 MILES
Hi. I have a troubleshooting and nobody could help me about it. It has a misfire detection on scanner, but I changed the ignition coils, spark plug and does not work. Every time is shaking. I do not like that, because is a great car. Please I need your help. I went to the mechanic but he only wants my money and cannot help me.
Thanks
Monday, July 2nd, 2018 AT 4:36 PM (Merged)
CARADIODOC
  • 33,757 POSTS
You also have to consider fuel and compression, especially at the mileage you listed. The fault code should specify which cylinder is misfiring. Swap that injector with one of the other ones and see if the misfire moves to the other cylinder.
Do a compression test.
HELLOTHERE
  • 2003 ACURA TL
  • 6 CYL
  • FWD
2003 Acura TL - Hesitates between 20-30 miles/hr (rarely higher speeds) and can **** you around until car seems to grab hold and go. Giving it more gas sometimes helps. Doesn't always do this. Seems to be worse in warmer weather. Was told it was my EGR valve by Acura. Replaced, but did not fix the problem.
Tuesday, April 7th, 2020 AT 1:20 PM (Merged)
  • 108,336 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
HELLOTHERE
No and no.
AROD1682000
  • 2003 ACURA TL
Any of you guys run into a low speed miss on 2003TL? It started 2-3 mos. Ago
. First occasionally, now everyday. At about 20-35 mph and light throttle,
the car starts to buck until you change throttle positon, then it responds
normal. It runs fine at full throttle at least to 115 mph and idles smooth,
Avg. Mileage around 25 mpg, same as always. Has 84K mi. On it. Gonna pull
the plugs and go from there. Thanks!
Tuesday, April 7th, 2020 AT 1:21 PM (Merged)
BRUCE HUNT
  • 3,753 POSTS
I might suggest a plug look as well. See if there is any oil in the plug holes. I might look at replacing the wires.
BMRFIXIT
  • 19,053 POSTS
The problem it may be a clogged EGR ports
Are you getting a misfire codes
You should check if you have any codes
I will look for the bulletin and will post it
BMRFIXIT
  • 19,053 POSTS
I will look for the bulletin and will post it[/quote:96be84263f]
https://www.2carpros.com/forum/automotive_pictures/99387_2003_1.jpg
FUNGUY4
  • 39 POSTS
  • 2001 ACURA TL
  • 6 CYL
  • FWD
  • 126,000 MILES
Hello I have a 2001 Acura Tl and after I have driven it for awhile then let it sit for an hour or so or sometimes just shutting it off then starting it back up, it will run a bit rough so in order to straighten it up I have to rev the engine up to get it to smooth back up and sometimes it throws a code. I have taken it to autozone and had them run a diagnostic on it and it comes up with cylinder 1 and 2 misfire. It doesn't do this that often but when it does the check engine light will come on but will shut of pretty quickly after coming on Thanks for any help ;)
KHLOW2008
  • 41,814 POSTS
Hi FUNGUY4,
Misfiring can be due to the ignition, fuel system or engine mechanicals.
Most common would be the ignition system concerning the spark plugs and related parts. Have them checked and repair as necessary.
If it is fuel related, it could be the injectors or fuel pressure.
Do you have any overheating or coolant losses issues?
FUNGUY4
  • 39 POSTS
HI, no I have no issues with overheating or any of the such so I think I have ruled out any head gasket issue. I bought the car when it had 108,000k, and in the maintenance records I have found no reciepts for a tune up so I am going to try to do a tune-up anyway since it probably needs one and see if that fixes the issue then I will go from there if not. Thanks for your help KHLow2008
ILLWILL13
  • 2001 ACURA TL
Engine Performance problem
2001 Acura TL 6 cyl Front Wheel Drive 153000 miles
my tl has all 6 cylnders misfiring and is sluggish as hell. Takes almost 30 seconds to get to 50 mph. I dont want to get burned by a mechanic so was looking for some info on what may be the problem. Thanks for everyones time
BLUELIGHTNIN6
  • 16,542 POSTS
If all cylinders are misfiring then there could be damage to the cylinder head. You will need to have a leakdown and compression test performed on the cylinders.
ACURATLTROUBLE
  • 2000 ACURA TL
  • 6 CYL
  • FWD
  • 150,000 MILES
I recently took my tl for a tuneup and 3 days after it was done my car started shaking and the codes told me most of my cylinders were misfiring. Do you think the mechanic messed up the tuneup and caused this?
CARADIODOC
  • 33,757 POSTS
Hi acuratltrouble. Welcome to the forum. If it's the mechanic's fault, why did it run fine for three days? Every mechanic fears the "ever since" syndrome. That's where anything that goes wrong days or weeks after he touched the car is his fault. There is very little involved today in a tune-up compared to thirty years ago. That's not to say, however, the new problem couldn't be related to the recent service. First you need to find out what the cause of problem is before assigning blame. A new spark plug could have a cracked insulator. That's not really the mechanic's fault but it is something he will take care of. A vacuum hose could have been knocked off during the service. If the rubber is old and deteriorated, disturbing it while removing other parts could have loosened it and it took three days to become disconnected due to normal engine vibration. Again, this is something he will take care of but it's not fair to blame him for overlooking a hose that he didn't touch and wasn't causing a problem when he had the car. Too many people have the attitude "well, he SHOULD have seen it". That means he should have been psychic! We really aren't that good. :)
Your new problem falls into one of three categories. It could be totally unrelated to the recent service, it could be an unintended byproduct of the recent service, or it could be a result of the recent service. A reputable shop / mechanic will determine the cause of the problem and do everything possible to make it right because they want you to be happy and come back again, but they also have to look out for the business and not give away too much for free. It can be very hard for them to have to explain why the new problem is just that and it's something you'll have to pay for.
Next, if their work led to the new problem, reputable shops will apologize and fix it at their expense. New parts can be defective, and some less-expensive aftermarket parts just don't work as expected in some cars. In the words of one manufacturer's trainer, "we not only sell you new parts, we provide them pre-broken". When this is the case, most shops will not charge additional labor to replace a defective new part. They CAN legitimately charge if a new part is needed that wasn't previously installed.
If something was damaged or done incorrectly that led to the new problem, reputable shops will repair it at their expense and often do something extra for you such as offering a free oil change. The key is the cause of the problem has to be identified first. Even then, less-than-reputable shops can just as easily make up a story about why the new problem isn't their fault. Usually those shops are already well-known, but regardless, they are the ones that give the entire industry a bad name.
The first thing you should do is contact the shop that did the tune-up and explain what is happening. They will most likely offer to look at it as soon as possible. If they claim it is not their fault and it's going to be an expensive repair, the next thing would be to get a second opinion from a different shop. Most shops don't like to cut down their competitors because making a competitor look small doesn't make them look big. I'd suggest you don't even mention the name of the shop that did the tune-up. If that first one IS less than reputable, the second shop may be predisposed to looking extra hard for something to blame on them that really might not be deserved.
Caradiodoc
JACK DAVIDSON
  • 41 POSTS
  • 1999 ACURA TL
  • 6 CYL
  • FWD
  • 180,000 MILES
I installed a new EGR valve, cleaned the intake manifold including the EGR port. Put SeaFoam in the gas, oil, and a little thru the vacume lines. I'm not getting any of the P0300 thru P0306 or P0401 DTCs anymore. BUT I'm still getting the P1399 DTC w/ a mild skip under load. The plugs are new Bosch 4428 +4 PLatinums What else could be causing the P1399? Or do I just need to let the SeaFoam work its" way thru the systems?
KHLOW2008
  • 41,814 POSTS
P1399 is a temporary code for misfiring and the misfiring code should be back sooner or later.
What is the plug gap setting?
Have you tested the coils?
