2CarPros - Car Questions & Answers
Acura Integra Repair Question
Topics covered: Axle, Chirping, Grease.
Asked on October 22, 2007
Speedometer Cable problem
Hi, I owned a Acura Integra GS 1990. One night I was driving my car at 65 mph and the M.P.H drop all the way to 0. Everything else work. The next day I took out the cluster to check up on the speedometer cable and I found out that it snap at the square end. What should I do to repair this? I do not know how to change this cable because I do no even know where it goes behind the dash. What should I do?
Avatar Asked by mrmikey05
Answer
Replied on October 22, 2007
You have the instrument cluster out? Be sue th espeedo head (gauge) turns freely and didnt cause the break. If ok, then go to Acura and buy the cable without the housing and pull it out of the housing. It goes to the speedo drive on the transaxle. Slide the new cable in with a little grease on it to keep it from chirping
Tiny Answered by 2CarPros Jack (expert)
12,033 answers provided
Thank you for your reply, I will do that.
Tiny Response from mrmikey05
1 question asked
