Replacing the water pump
TOYE
  • 2005 JEEP LIBERTY
  • 6 CYL
  • 4WD
  • 48,875 MILES
Hello, I am replace the water pump myself. Did I miss anything here? Drain the the antifreeze, remove the belt, unbolt the water pump, remove it and replace it with the new one do the steps in reverse. Do I need to replace the thermostat and the gasket at the same time? Please help, thanks
Saturday, November 22nd, 2008 AT 9:26 AM
SQM
  • 6,383 POSTS
Before removing the water pump you will have to drain the coolant. Remove the drive belt and the radiator fan.
Remember to only work on the cooling system when the engine is cool.
Here is a helpful guide:
https://www.2carpros.com/articles/water-pump-replacement
It will be a good idea to change the thermostat and gasket as you will have all the components apart.
I have attached the complete replacement procedure below.
Tuesday, November 30th, 2021 AT 12:39 PM
