Images (Click to make bigger)
SPONSORED LINKS
Thursday, March 17th, 2011 AT 9:07 PM
MEIERLISA
MEMBER
2001 FORD ESCORT
4 CYL
FWD
AUTOMATIC
Need intructions for serpintine belt change for 2001 zx2 ford escort
Monday, October 8th, 2018 AT 11:54 AM
(Merged)
MECHANIC
Removal and Installation
1. Raise and support the vehicle.
2. Rotate the drive belt tensioner clockwise and remove the drive belt.
3. NOTE: Refer to the Component Locations for the drive belt routing.
To install, reverse the removal procedure.
(Merged)
TCHANCEY
MEMBER
1999 FORD ESCORT
Engine Mechanical problem
1999 Ford Escort 4 cyl Front Wheel Drive Manual
Do you have a diagram for the drive belt for this automobile?
(Merged)
MUSTANG87
MECHANIC
Ure car has it on the bottom of hood or somewhere round the front hood lock area. Look around for it it has it . Its in a sticker form
SPONSORED LINKS
(Merged)
TCHANCEY
MEMBER
Thank you for responding. However, the sticker is gone and I didn't find the diagram in the repair manual. That's why I'm hoping someone has one I can look at online. Anymore ideas?
(Merged)
MUSTANG87
MECHANIC
Go to a auto parts store like auto zone kragen etc they can help. And u can also look at another car like yours, go to a junk yard and look for an escort even an older escort all escorts have same engine just get the sticker off of a junked escort and take it home.
(Merged)
MUSTANG87
MECHANIC
Hey sorry nOt 100 percent sure on older escorts with 1.8 liter but might possibly be same diagram. FOR SURE LOOK AT A 97 TO 99 ESCORT OR ZX2 ESCORT WITH SAME ENGINE WITCH IS A 2.0 L4 most likely u may find one in a junk yard and take the sticker with diagram home and stick it on ur car. Also your local ford dealer can help. Good luck
(Merged)
BRYANDRRY
MEMBER
1999 FORD ESCORT
4 CYL
FWD
AUTOMATIC
122,000 MILES
What is the belt routing for the 99 escort zx2?
(Merged)
BMRFIXIT
MECHANIC
Here what i have hope that help
let me know
(Merged)
BRYANDRRY
MEMBER
Thank you very much. I actually was able to figure it out but man it was a pain to put on. I did the borrow a tool thing from the parts store and the one I got was too long for the car and I couldnt get enough room to move the tensioner far enough to put the belt on so I had to manhandle on with the tensioner moved as far as possible. Not my funnest 3 hours working on the wifes car.
But thanks again
(Merged)
WANDA
MEMBER
2002 FORD ESCORT
How does the serpatine belt go on a 2002 ford esscort?
SPONSORED LINKS
(Merged)
MECHANIC
On the home page, go to the belt routing diagrams site and put in the information for your vehicle to get the routing diagram needed.
(Merged)
CHAPPY72
MEMBER
1999 FORD ESCORT
4 CYL
2WD
AUTOMATIC
100,000 MILES
I need a serpentine belt diagram as well as where is the belt tensionor and how to tighten belt. All this for a Ford Escort zx2
