1989 Oldsmobile Cutlass HELP
SHAFFER017
  • 1989 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 14,939 MILES
My car runs fine when its cold. When it gets up to operating temp it starts to flutter then die then it wont start for about 1 hour then will run fine till it gets hot again. I replaced the egr valve the coil packs and the icm, and fuel filter and I still have the same problem. I took in to a shop and hooked it up to a computer and flashed no codes and tested the fuel pressure from the fuel rail and tested good, but told me the EGR valve was electronicly unplugged. They plugged it in and seemed to run fine. So I left and two blockes down the road it flutters and dies while im driving. It doesnt matter if im driving or im parked it does the same thing
Monday, March 9th, 2009 AT 2:09 AM
Don't wait for an hour do below immediately to catch it
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, March 9th, 2009 AT 2:20 AM
SHAFFER017
I tried that when it died I checked for spark and there was no spark at all but when I wait it sparkes again and when they checked the fuel pressure it was at 37 psi
Monday, March 9th, 2009 AT 2:30 AM
Check and test the crankshaft positioning sensor.
Monday, March 9th, 2009 AT 2:39 AM
SHAFFER017
Ok what will I be looking for what should it test to and were is it located on 3.1L v6
Monday, March 9th, 2009 AT 2:50 AM
The CPS is on the right front of engine
https://www.2carpros.com/forum/automotive_pictures/12900_cps1_7.jpg
Monday, March 9th, 2009 AT 7:18 AM
Related Engine Stall While Driving Content
