Images (Click to make bigger)
SPONSORED LINKS
Wednesday, September 2nd, 2009 AT 2:34 PM
JASONLEEBRIGGS
MEMBER
1 POST
1991 TOYOTA PICKUP
4 CYL
4WD
MANUAL
218,000 MILES
The thermostat froze closed and the radiator overheated and cracked. I replaced the radiator and the thermostat.
Overheating is still a problem. I removed thermostat and truck stays cool. I opened the radiator and water is moving (meaning water pump is working?). I replaced thermostat again with a new one and still overheats.
Could new radiator and thermostat be rated at different temps? Do I keep getting bad thermostats?
Saturday, January 5th, 2019 AT 12:25 PM
(Merged)
MISSY2SHOES
MEMBER
Try flushing your system. You may have a blockage in the heater core. Dont make the mistake of putting your thermostat in backwards, And yes can be done.
(Merged)
2CP-ARCHIVES
MEMBER
1991 TOYOTA PICKUP
Where is the thermostat located on a 91 4
wheel drive Toyota pickup
Saturday, January 5th, 2019 AT 12:27 PM
(Merged)
KHLOW2008
MECHANIC
If you follow the upper radiator hose to engine, you would come to the thermostat housing, inside which is the thermostat.
SPONSORED LINKS
(Merged)
FLOPSTER54
MEMBER
1 POST
1992 TOYOTA PICKUP
Engine Cooling problem
1992 Toyota Pickup 6 cyl Four Wheel Drive Automatic
Hello there, I can't find thermostat. Do you know where it is?
(Merged)
MECHANIC
The thermostat is located in the thermostat housing at the bottom radiator hose where it connects to the engine block.
DRAIN ENGINE COOLANT
DISCONNECT RADIATOR OUTLET HOSE
REMOVE THERMOSTAT
(a) Remove the 3 nuts. water inlet and thermostat with gasket from the water pump.
(b) Remove the gasket from the thermostat.
(Merged)
NETERONE
MEMBER
1 POST
I need to know the location of a thermostat on a 1992 pickup 2wd 4 cylinders thanks.
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
The thermostat for these engine is in the bottom radiator hose as well. Under the thermostat housing at the block.
(Merged)
KEVINJOE
MEMBER
1 POST
1993 TOYOTA PICKUP
1993 Toyota Pickup 6 cyl Four Wheel Drive Manual
need to know where thr thermastat is located
(Merged)
BLUELIGHTNIN6
MECHANIC
The thermostat is in the bottom radiator hose where it connects to the motor.
