2006 Toyota Camry Front brake and Rear Brake, which one sho
FATMAN888
  • 2006 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 40,000 MILES
My 2006 Toyoto Camry was bought just 2 years ago. I went to the dealer for a regular maintenance and they indicated that the rear brake pad is only 30% remaining. I am just wondering if this is normal. I think during braking, most of the force are on the front brake. Why should the rear brake wear faster than the front? Just 8 months ago, their inspection said that both front and rear pads are 75% remaining. By proportion, it should not be wearing that fast in the last 8 months from 75% to 30%. Could that be some other factor causing this? Appreciate your help.
Thursday, May 29th, 2008 AT 2:18 PM
KHLOW2008
  • 41,814 POSTS
Stiff or stuck slider bolts and/or pistons can cause the problem.
Sure no error with the guy who gave the report?
Thursday, May 29th, 2008 AT 2:50 PM
MERLIN2021
  • 17,250 POSTS
Rule of thumb is most rear pads last at least as long as the front brakes, 30% seems like a number just thrown out there, pads only need to be replaced when the are worn to a thickness equal to or less than the plate they are glued to, see if you can look at them to find out. Or go to a tire shop and get a second free opinion!
Thursday, May 29th, 2008 AT 2:53 PM
Related General Content
