Electrical problem
1993 Toyota Camry 4 cyl Front Wheel Drive Automatic
passanger side window will go down but not up.
Monday, June 21st, 2010 AT 1:40 PM
MECHANIC
These are a switch over motor, that is the pos and neg switch polarity to change direction, so if the window will go in one direction the motor will be ok, so I would be checking the switch first.
Mark (mhpautos)
Tuesday, June 22nd, 2010 AT 4:13 AM
INANEIGHLY
MEMBER
Window rolls down check it and it is getting power and the switch will work for the window to go down but not up. Could their be a short in the wiring that could not be making a connection to it going up but it works for it to go down.
Tuesday, June 22nd, 2010 AT 8:31 AM
INANEIGHLY
MEMBER
The switch works hooked it up to the back window and tested it and it works.
Tuesday, June 22nd, 2010 AT 8:34 AM
MECHANIC
Does it work from the drivers master switch?
Mark (mhpautos)
Tuesday, June 22nd, 2010 AT 8:50 AM
INANEIGHLY
MEMBER
Yes it went down with that switch but not up.
Tuesday, June 22nd, 2010 AT 1:26 PM
MECHANIC
Last time I had one of there with this problem it was a faulty switch pack, but this will have to be tested by a mechanic.
