HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Avalon
Brakes
Pads
Rear
SPONSORED LINKS
Pads and rotor installation
CARLA ROBERSON
MEMBER
2008 TOYOTA AVALON
167,000 MILES
Brake pads and rotor installation please help.
Wednesday, August 24th, 2016 AT 5:07 PM
MECHANIC
Here is a guide that will help with this: Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Here is a guide on how to retract rear calipers: This video shows the job being done on a similar car but the process is the same.
https://www.youtube.com/watch?v=j8YwfSKEzZo&t=29s
Below is the process from the manual that will show how to do this. Please let us know if you have other questions. Thanks
Images (Click to make bigger)
SPONSORED LINKS
Monday, May 10th, 2021 AT 5:48 PM
ASHSUZAN
MEMBER
2005 TOYOTA AVALON
Can I change the rear brakes?
Monday, May 17th, 2021 AT 5:10 PM (Merged)
MECHANIC
Here are some guides that will help with this:
Plus below you will find the info from the manual on how to replace the rear brakes.
Please run through this material and let us know if you have other questions. Thanks
Please
login
or
register
to post a reply.
Related Brake Pad Rear Content
Today I Was Checking The Brakes And I Saw The Front...
Today I Was Checking The Brakes And I Saw The Front Pads Are Low.
Asked by
alouy15
1 ANSWER
13 IMAGES
2013
TOYOTA AVALON
VIDEO
How to Replace the Rear Brake Pads and Rotors
Instructional repair video
GUIDE
Pad and Rotor Replacement - Rear
Step by step instructions on how to replace automotive rear brake pads and rotors. This article pertains to all rear disc brake vehicles. Begin with the vehicle on level...
Dealer's Service Rep Said That They Recommend...
I Just Had The Toyota Recommended Service For 45000 Miles And The Dealer's Service Rep Said That They Recommend Front Brakes
Asked by
gbetler
1 ANSWER
9 IMAGES
2007
TOYOTA AVALON
Do I Need Some Special Tool Or Code Generator To...
Hi, I Have A 2001 Toyota Avalon Xls That Keeps Wearing Out The Right Front Brake Pads. The Caliper That Has A Torn Boot On The Piston So I...
Asked by
tmnd777
1 ANSWER
1 IMAGE
2001
TOYOTA AVALON
No Brake Fluid Going To Right Rear - Brakes Wont Bleed...
I Replaced All Brake Pads Front And Rear And Went To Bleed The System Starting From The Furthest Wheel From The Master As I Was Taught And...
Asked by
topdad1947
1996
TOYOTA AVALON
How Do You Properly Bleed A Brake System
How Do You Properly Bleed A Brake System For A 1996 Toyota Avalon Xl? How Do You Install New Rear Calibers?
Asked by
vrclark
1 ANSWER
5 IMAGES
1996
TOYOTA AVALON
VIEW MORE
SPONSORED LINKS
Replace Rear Brake Pads and Rotor Ford Edge
Brake Pad & Rotor Replacement Mini Cooper
Rear Brake Pad - Rotor Change Hyundai
Online car repair manuals
