Oxygen sensor location and replacement?
KMARTINS77
  • 2004 PONTIAC GRAND AM
  • 15,000 MILES
I need to know how many O2 sensors does. Where are they located? How can I replace?
Monday, May 14th, 2012 AT 6:42 PM
Here is a guide to help walk you through the steps with the instructions in the diagrams below.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Monday, May 14th, 2012 AT 6:50 PM
KMARTINS77
Thank you the guide helped me alot.
Monday, May 14th, 2012 AT 8:30 PM
Nice work, we are here to help, please use 2CarPros anytime.
Monday, May 14th, 2012 AT 9:39 PM
BROWNSUGARDN
Where is the locations of the oxygen sensors?
Thursday, December 3rd, 2020 AT 8:04 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Ther should be one in the exhaust pipe before the cat converter (4 cyl) on a v-6 there will be 2 before the cat converter, one in each exhaust down pipe or manifold. The are the only thing in the exhaust system with wires. Look around, you can find them
HERIVA1018
  • 2002 PONTIAC GRAND AM
Where is the oxygen sensor? Also do you have any pictures to assist
Thursday, December 3rd, 2020 AT 8:05 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello, you have two - number 5 on the first pic
https://www.2carpros.com/forum/automotive_pictures/248015_oxy_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_oxy_2_1.jpg
DWISE
Engine Performance problem
2002 Pontiac Grand Am 4 cyl Automatic 73000 miles
My car was riding rough and the service engine light came on. The dealer said the diagnostic codes said it was misfiring. They changed an ignition pack and said I'll need spark plugs soon (at first they said it was a coil pack that needed to be replaced).
The very next day my service engine light came back on again. I took the car back and they're now saying it's because of the oxygen sensor after the catalytic converter.
Now, originally before I went to the dealer, the Midas Muffler company told me the problem was with the catalytic converter but I could go to the dealer and get it fixed for free because it was still under warranty.
I don't know who to believe. Is the dealer nickle and diming me now until my warranty runs out or does this seem okay? Please help.
DON OLIVER
  • 101 POSTS
A cat converter will probably not set a check engine light or cause a misfire. The misfire is usually from the ignition system. The dealer repaired the misfire. The o2 after the cat could have been contaminated with the excess fuel from the misfire condition. If the cat is clogged, the engine will run fine at idle but will bog down under load. If the car runs fine, it is probably the o2. They do need replacing at recommended intervals or when they fail. A decent snan tool will show the data stream and you can see if the o2 is cycling properly. Good luck
SCND2NUN
  • 2001 PONTIAC GRAND AM
  • 6 CYL
  • 69,785 MILES
Where is the front oxygen sensor located in the 2001 Pontiac Grand Am GT1. V-6 3.4L? I have the part and want to change it due to a SES light but just need to find it. Thanks.
Thursday, December 3rd, 2020 AT 8:13 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
What is the code number you have there is two front o2 sensor on that engine bank1 and bank2 you don't want to change the wrong one.
SCND2NUN
The code was 02 htr ckt. B1 s1. So I have the sensor before the converter.
SATURNTECH9
  • 30,869 POSTS
If you could give me the actual code number that would really help me find the info it's a P followed by a four digit number.
ALATUAL
  • 6 CYL
  • FWD
  • 67,000 MILES
My Service Engine Soon light came on and was diagnosed with a P141 error. It indicated that the BB1 (Bank 1) Sensor 2 had a problem. The question is where is the Bank 1 Sensor 2 located on my 2001 6-cylinder Grand Am. Thank you.
MMPRINCE4000
  • 8,548 POSTS
It would be the downstream sensor, located after the convertor in exhaust system. The P0141 code is an O2 heater malfunction. These are heated sensors (4 wire). The sensor will have to be replaced.
SCND2NUN
Sorry, P0135.
SATURNTECH9
  • 30,869 POSTS
I'm sorry I thought your engine had two upstream o2 sensor's it only has one.I posted a diagram of where it is sorry about that.I recommend using a o2 sensor socket to change it but you don't that's up to you.
MICKEY11
  • 2000 PONTIAC GRAND AM
  • FWD
  • 175,000 MILES
I have a 2000 Pontiac Grand Am Gt 6 Cyl 3.4L and need to replace the upstream oxygen sensor. I have had it diagnosed with code P0131. I just need a diagram of where the sensor is located as only the downstream sensor is shown in my repair manual.
Its on the right exhaust manifold
MICKEY11
A million thanks!
