P0651 code
2008 CHEVROLET COBALT
170,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
COREAVE
5vB is missing (5v2).
Sep 13, 2019 at 6:52 PM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. Here is a circuit description so you can see what is controlled on the 5 volt reference:
Collision
 62
2008 Chevrolet Cobalt
L4-2.2L
P0651
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0651
P0651
DTC P0641 or P0651
Diagnostic Instructions
 *  Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
 *  Review Strategy Based Diagnosis for an overview of the diagnostic approach.
 *  Diagnostic Procedure Instructions provides an overview of each of the diagnostic category.
DTC Descriptors
DTC P0641
 -  5-Volt Reference 1 Circuit
DTC P0651
 -  5-Volt Reference 2 Circuit
Diagnostic Fault Information
Open In New TabZoom/Print
Circuit/System Description
The engine control module (ECM) has 2 internal 5-volt reference busses called 5-volt reference 1 and 5-volt reference 2. Each reference buss provides 5-volt reference circuits for more than one sensor. A fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference buss. The ECM monitors the voltage on the 5-volt reference buss.
The 5-volt reference 1 buss provides 5 volts to the following sensors:
 *  The manifold absolute pressure (MAP) sensor
 *  The fuel tank pressure (FTP) sensor
 *  The air conditioning (A/C) refrigerant pressure sensor
 *  The accelerator pedal position (APP) sensor 2
 *  The exhaust camshaft position (CMP) sensor
 *  The intake CMP sensor
The 5-volt reference 2 buss provides 5 volts to the following sensors:
 *  The APP sensor 1
 *  The throttle position (TP) sensor 1 and 2
 *  The crankshaft position (CKP) sensor
 *  The secondary air injection (AIR) solenoid
At the throttle body, back probe the grey wire on the connector with key on engine off.since the 5 volts is missing, unplug the connector with the probe still attached. If the 5 volts comes back on the throttle is bad. If no 5 volts then start unplugging every component on bus 2. The APP is the accelerator pedal so unplug it. If the 5 volts comes back on then the APP is bad and if not unplug every component until you get 5 volts back. Let us know what the test results are.
You can also work backwards and unplug everything in that circuit and plug one item at a time until you lose the 5 volts to isolate the problem. If you have any questions, don't hesitate to ask.
Sep 13, 2019 at 9:36 PM
COREAVE
Turned out to be Secondary Air Injection Shut-Off and Check Valve found one at junk yard $25 all fixed.. Thanks for your guidance
Sep 17, 2019 at 9:30 PM
JIS001
  • 3,412 POSTS
Hello and welcome back. Glad to hear you were able to narrow it down to the air injection. Please use 2CarPros if you ever need our assistance again.
Sep 17, 2019 at 9:37 PM
