Overdrive does not kick in for a long time temperature gauge stays at half
1989 TOYOTA CAMRY
250,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MICHAELMCC
MEMBER
FOLLOW
Temperature at half and overdrive does not Kick in for long time. What should temperature run at?
Nov 16, 2018 at 6:51 AM
JONNYB1963
CERTIFIED EXPERT
Good morning,
Temperature sounds good so it is not related to this issue.
When you cycle the switch on the shift knob (to turn the O/D off), do you see a light on the instrument cluster that says O/D Off? And when you press the switch again will that same indicator light go out?
Jon
Nov 16, 2018 at 9:14 AM
JONNYB1963
CERTIFIED EXPERT
Coolant temperatures should be around 190 degrees typically.
Nov 16, 2018 at 9:15 AM
JONNYB1963
CERTIFIED EXPERT
Are able to read any codes on the vehicle? Is the check engine light on at all?
Nov 16, 2018 at 9:18 AM
MICHAELMCC
MEMBER
Yes, light works.
Nov 16, 2018 at 9:38 AM
MICHAELMCC
MEMBER
New EFI temperature and TPS.
Nov 16, 2018 at 9:39 AM
MICHAELMCC
MEMBER
It does show number but temperature gauge has not ever went up past half way. I put card board in front of radiator and still only half it took about twenty to twenty five miles for over drive to kick in.
Nov 16, 2018 at 9:41 AM
JONNYB1963
CERTIFIED EXPERT
Okay, so you are saying that the O/D light works correctly when you operate the switch?
Nov 16, 2018 at 9:58 AM
MICHAELMCC
MEMBER
Yes, it goes off and on with switch.
Nov 16, 2018 at 11:13 AM
MICHAELMCC
MEMBER
It acts like it wants to kick in like it surges then nothing then twenty miles up road it kicks in.
Nov 16, 2018 at 11:16 AM
JONNYB1963
CERTIFIED EXPERT
Okay thanks for that.
Sorry for so many questions but I have the disadvantage of not being there to see it for myself and it is the best way I know to solve the problem. Have you tried checking the level of the transmission fluid and if so did you notice the color of the fluid? If it was dark, and smelled burnt, it would be time to change the fluid and filter. If it is full then we need to move on to something more involved.
Jon
Nov 16, 2018 at 11:46 AM
MICHAELMCC
MEMBER
Now on way home it goes in overdrive quick, but now it goes in and out constantly.
Nov 16, 2018 at 5:33 PM
JONNYB1963
CERTIFIED EXPERT
Michael,
Can you comment about the transmission fluid. I advised you to check the level and the color. Can you fill me in on what you found?
