Still overheating after replacing water pump and gaskets
FAMOUSO
  • 2010 FORD
  • 3.7L
  • V6
  • 4WD
  • 500 MILES
I changed the water pump and gaskets and it is still overheating.
Wednesday, October 12th, 2016 AT 12:21 PM
HMAC300
  • 48,601 POSTS
If it is overheating then have it pressure checked for a head gasket. If it does immediately after starting car check thermostat. Also check radiator for cold spots if you feel any then rad is bad should be same temperature all over and make sure all air is out of system.
Wednesday, October 12th, 2016 AT 12:40 PM
Related Water Pump Replace/Remove Content
Water Pump Replacement
VIDEO
