Frontier Excessive Oil
EDNKAREN01
  • NISSAN FRONTIER
Have a 2001 Frontier, 426,000 miles (YES!) Seems that too much oil is passing through the crankase exhaust hose which is connected to the air filter assembly. What is causing this? I am loosing about 1 1/2 quarts of oil every 3,000K and I believe some of it is because of this. Have to replace air filter more often than usual.
Do you
have the same problem?
Tuesday, January 16th, 2007 AT 8:47 PM
Try changing the PCV valve
Tuesday, January 16th, 2007 AT 8:49 PM
Recommended Guides
