Hi there,
Are you needing the ignition timing ? Here is the diagram the book shows (below). Warm up engine, shut off, disconnect T.P.I. sensor start and rev to 2,000 RPM 2 or 3 times. Let idle check timing, if require d adjust by backing off clamp at distributor and re setting. turn off & connect TPI. Timing settings 18-22 @ 700-800 rpm.
Mark (mhpautos)
Jul 19, 2008 at 11:26 PM
