1993 Nissan Altima Electrical problem
1993 NISSAN ALTIMA
135,000 MILES • 4 CYL • FWD • AUTOMATIC
DADELAR
I recently bought a second 1993 Altima as a project car with the intention of replacing needed parts from the Altima that I already had (accident victim!). The new Altima had a wiring problem where a bundle of wires that are routed over the drivers side wheel well had fallen and was rubbed raw by the front wheel . (For some reason, somebody had removed the wheel well covers from both front wheels.) It appears that a bundle of wires coming from the firewall side of the engine came into a connector that split the wires going to the front of the car. My guess would be lights and other devices sharing the same supply. I painstakingly rewired the bundle using connectors from the old car, paying close attention to matching wire-to-wire. I now have a problem that the engine won't shut off when I pull the key!! (I have to pull the fuel pump breaker to shut the engine down.) Now - it looks to me like someone has done this before just by the way the breaker and surrounding area looks. It doesn't make sense to me that the rewiring that I did would cause this. Does any of this make sense???
Jun 16, 2008 at 9:53 AM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Hi dadelar,
When the engine won't cut off, it means power is still being supplied without the ignition switch being on.
Some people likes to put a timer to cut off after key is pulled out, I don't know for what reasons other than wasting fuel, so check and see if the engine cuts off say after 1 or 5 mins.
A faulty ignition switch is also possible.
Other than the above, I can only think of improper wiring. You need to check the power source after the key is turned off.
Jun 16, 2008 at 12:52 PM
