Can you tell me where is igition coil B located?
ASK MECHANIC
  • 2007 LEXUS RX 350
  • 65,000 MILES
Can you tell me where is igition coil B located on my Lexus 2007 RX350?
I have an engine light on my RX350. I plugged in OBD2 and it said PO352 Igition Coil B Primary/secondary.
Do you
have the same problem?
Tuesday, July 31st, 2012 AT 12:13 AM
SATURNTECH9
  • 30,870 POSTS
I posted a diagram for you its the ignition coil for the number 2 cylinder. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Tuesday, July 31st, 2012 AT 12:28 AM
LINDA MAHONEY
  • 2007 LEXUS RX 350
  • V6
  • 137,000 MILES
Check engine light on and code is P0352. From what I have read this is ignition coil #2, want to know where located. Last year had replaced ignition coil #6 and was charged more for labor because mechanic said located in back and required more labor. From everything I have read #2, 4, 6 are locsted in front with easy access. Don't want to get beat out of more money for labor.
Saturday, March 30th, 2019 AT 12:47 PM (Merged)
HMAC300
  • 48,606 POSTS
See pics first one is what can cause that code second of cyl id for a v6 because engine size does not come through on new system yet.
LINDA MAHONEY
Can't tell from diagram. Is ignition coil #2 easy access or is more labor required to get to # 2 ignition coil
HMAC300
  • 48,606 POSTS
The ignition coil for #2 wold be on front side if engine is sideways in this vehicle. Passenger side.
LINDA MAHONEY
I Got it repaired this morning. You were a big help.
HMAC300
  • 48,606 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
