Changing transmission fluid
RBESERRA
  • 1998 KIA SPORTAGE
  • 4 CYL
  • 4WD
  • 159 MILES
How many quarts of transmission fluid need to be added after changing?
Sunday, March 1st, 2009 AT 11:09 PM
  • 108,328 POSTS
Here is a video that shows the job being done with the fluid specs below.
https://youtu.be/5NmhYcl6cAo
Fluid Types
Fluid Type
Transmission .................... Dexron - II E or M III
Capacities
Fluid Capacity
Transmission total (Excluding cooling lines) .................... 7.08 US qts (6.7 L)
Drain and refill .................... 2.7 qts. (2.5L)
Friday, March 6th, 2009 AT 10:15 AM
CHICO23
  • 38 POSTS
If the color is like a pink color it means that the transmission has water. Get and change the fluid and the transmission filter
Thursday, September 12th, 2019 AT 1:55 PM (Merged)
