Keeps breaking flywheel
1996 FORD EXPLORER
160,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DAVID LIGHTFOOT
Engine cranks and rev's high, 2500 rpm's, I do not know if this is causing flywheel to break.
Aug 31, 2016 at 1:12 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner, look for a vacuum leak and check starter for flywheel breakage or make sure you are not putting a cheap knockoff on it that may be the problem.
Sep 1, 2016 at 6:57 AM
