Firing Order
JULIJEPSEN
  • 2004 ISUZU RODEO
  • 6 CYL
  • 127,000 MILES
2004 isuzu rodeo 3.5L - What's the ignition coil sequence? I know that coil #4 is bad, but don't know the sequence/ which coil is #4?
Do you
have the same problem?
Sunday, February 6th, 2011 AT 5:22 PM
KHLOW2008
  • 41,815 POSTS
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Tuesday, February 8th, 2011 AT 4:47 PM
TROYD07
  • 2004 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 100,000 MILES
Doin a timing belt on my 04 rodeo and I need to line the cams back up- repair manual says to make sure it is on the number two cylinder but I cannot find the firing order anywhere--little help please?
Wednesday, October 3rd, 2018 AT 6:39 PM (Merged)
  • 31,938 POSTS
Hi there,
timing belt set up as per pics.
mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_1_2.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic2_1.jpg
SMOKEYWILD
  • 2005 ISUZU RODEO
  • 2.4L
  • 4 CYL
  • MANUAL
  • 230,000 MILES
Hello
Could you please help with the firing order for my rodeo if you have a diagram would be much appreciated
Regards matthew
WRENCHTECH
  • 20,758 POSTS
We don't show a Rodeo made in 2005 here in the US.
SMOKEYWILD
Im in Australia brisbane its a rodeo 2005 petrol 4 cylinder 2.4 L thank you
DELVENUA
  • 2002 ISUZU RODEO
  • 2.2L
  • 4 CYL
  • 180,000 MILES
Can u please show me a diagram of the firing order for my engine and the timing marks my water pump recently stopped working while I was driving causing my timing belt to slip off
So now my hubby is needing help with the firing order and the timng points to my 2002 isuzi rodeo
WRENCHTECH
  • 20,758 POSTS
If that belt slipped off while the engine was running, then you could be in deep trouble. This is an interference engine and it will bend the valves almost instantly.
http://i1198.photobucket.com/albums/aa448/Wrenchtech/89110885.gif
http://i1198.photobucket.com/albums/aa448/Wrenchtech/89110887.gif
