Spark plug gap and replacement
HANSDAKIN
  • 1999 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 150,000 MILES
Hello would you tell me what the spark plug gap is 6?
Thank you
Wednesday, September 29th, 2010 AT 11:57 AM
WRENCHTECH
  • 20,757 POSTS
Here is a guide to show you how to install the spark plugs correctly with the spark plug gap - Plug Gap 1.0 - 1.1 mm (0.04 - 0.043 in)
https://www.2carpros.com/articles/how-to-change-spark-plugs
Wednesday, September 29th, 2010 AT 12:01 PM
CHRIS AGUAYO
  • 1995 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 170,000 MILES
The boots on the sparkplug wires didnt come out with the wires is there a special tool for this problem and where can I get it
Tuesday, February 12th, 2019 AT 2:55 PM (Merged)
CHRIS AGUAYO
BOBMCCLURE
  • 2001 ISUZU RODEO
  • 4 CYL
  • 65,000 MILES
Where are the spark plugs located?
MERLIN2021
  • 17,250 POSTS
If you don't see them, chances are you have Coil On Plug system, each plug has it's own coil, unplug it twist and pull up, and the plug is under it, you will need an extesion to reach it!
