2004 Hyundai Santa Fe Throttle Position Sensor
MOVINONUP12000
  • 2004 HYUNDAI SANTA FE
  • 6 CYL
  • AWD
  • 170,000 MILES
I want to replace the throttle position sensor in a 2004 Sante Fe. Where is this located and for a novice, how long should this approximately take?
Friday, January 1st, 2010 AT 9:34 PM
Its gonna take about lil bit over 1/2hr see location below
https://www.2carpros.com/forum/automotive_pictures/12900_tps_1.gif
Friday, January 1st, 2010 AT 9:46 PM
MOVINONUP12000
Rasmataz, thank you. The information you provided was very helpful. It took only 20 minutes.
Tuesday, January 5th, 2010 AT 12:29 PM
DARANNEAL
Did this require removing the large black housing to get to
It?
Monday, January 16th, 2017 AT 1:38 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
No it is right on the side of the throttle body, if you don't have a throttle cable you have an electronic throttle in which case you cannot replace the TPS you need to replace the entire unit.
Please let us know what happens so it will help others.
Best, Ken
Saturday, January 21st, 2017 AT 1:38 AM
MDPRATHER
  • 6 CYL
  • 70 MILES
I am trying to replace the TPS on my 2004 and can not find it on the vehicle. Do you have a picture or diagram on where I might find it on the 3.5L engine?
Thanks Matt
Saturday, January 21st, 2017 AT 1:40 AM (Merged)
Don't have the info on this but normally for the Tiburon/other models its located within this area-check there
MDPRATHER
Thank you, will check again at first daylight :)
ARTYSTA
  • 85,000 MILES
Seen you showed a diagram to another person in a post (https://www.2carpros.com/questions/hyundai-santa-fe-2004-hyundai-santa-fe-throttle-position-sensor--2) for the location of the TPS on a 6 cylinder 2004 santa fe. I believe I have the same problem. went to use mine and the acceleration is not working when I press on the gas pedal. My model is a 2004 Santa Fe diesel 4 cylinder 113 HP CrDI engine (I'm in Spain).
I tried desconnecting the battery to clear the engine control; I saw in another post that sometimes help to reset the computer and fix the problem (temporarily) but no luck. If you could at least show me a diagram of where I need to locate the TPS I would appreciate it very much. thanks for your time. Gene
  • 108,262 POSTS
The only info I can find on a 4 cylinder shows it on the top right of the engine. The info I found doesn't even show if it is a diesel. They are not in the US to the best of my knowledge.
FIXITMR
  • 9,990 POSTS
I was wonderin if the diesel even has a TPS?
  • 108,262 POSTS
You know, fixtmr, I don't think they do. However, the only info on a 4 cyl I could find was what I listed. Thanks to Mitchel, it wasn't even listed as a gas or diesel. But, I do agree with you.
GRIFF09
  • 2001 HYUNDAI SANTA FE
  • 4 CYL
  • 120,000 MILES
Engine Performance problem
2001 Hyundai Santa Fe 4 cyl Two Wheel Drive Automatic 120000 miles
I have been experiencing rough starts and issues with high/low idle for a couple of weeks, along with the check engine light recently coming on. Diagnostic check shows problems with oxygen sensor and throttle position sensor.
I don't have a problem locating the Bank 1 oxygen sensor 1, but the throttle position sensor is a new one. Can anyone assist in sharing where this is located, and how I replace it?
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Your TPS (Throttle Position Sensor) is located on the right side of the throttle body of your 2.4L engine.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_112.jpg
Removal and installation of the TPS is quiet simple.
REMOVAL:
Disconnect the TPS harness connector and remove the mounting screws. Remove TPS from throttle body.
INSTALLATION:
To install, reverse removal procedure. Tighten the TPS mounting screw(s) to 13 - 22 Ft. Lbs. (1.5 - 2.5 Nm)
Hope this helps..
Thanks for using 2carpros.com!
