2001 Honda CRV
DKOPLAN
  • 2001 HONDA CRV
2001 Honda CRV
auto shop (recommended by AAA) want to charge $635 for installing a brand new distributor. They say it requires 3 and 1/2 hr. Is this reasonable?
Saturday, August 8th, 2009 AT 10:48 AM
R/R the distributor takes about 45 mins.-get out of there its a rip off deal. See below
https://www.2carpros.com/forum/automotive_pictures/12900_distributor_2.jpg
Saturday, August 8th, 2009 AT 9:28 PM
KARYN5
  • 1999 HONDA CRV
  • 4 CYL
  • 159,000 MILES
Replacing a distributor on my suv
Thursday, August 15th, 2019 AT 7:17 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Distributor can only be plugged in one way.
Removal:
1. Disconnect the connector from the distributor.
2. Disconnect the ignition wires from the distributor ignition (DI) cap.
3. Remove the mounting bolts from the distributor, then remove the distributor from the cylinder head.
Installation:
1. Bring the No.1 piston to compression stroke TDC.
2. Coat a new 0-ring with engine oil, then install it.
3. Align the lug on the end of the distributor and its mating grooves in the camshaft end, then slip the distributor into position.
NOTE: The lug on the end of the distributor and its mating grooves in the camshaft end are both offset to eliminate the possibility of installing the distributor 180° out of time.
4. Install the mounting bolts, and tighten them lightly.
5. Connect the ignition wires to the distributor ignition (DI) cap as shown.
6. Connect the connector to the distributor.
7. Set the ignition timing.
8. After setting the ignition timing, tighten the mounting bolts.
See diagrams below
CPRICE213
  • 1999 HONDA CRV
  • 4 CYL
  • 113,000 MILES
Car was running fine but it did need a new Catalytic converter. Car was idling when it started to make a funny noise. I turned it off. Waited and when I tried to start it again it would not come on. Car would crank but just wouldn't start. I had it towed to Firestone and they said it needs a new distributor. Cost 650. Does this sound accurate?
KHLOW2008
  • 41,815 POSTS
Hi cprice213,
The symptoms do indicate a possible fault with the distributor and the cost varies between from where you are located. To get an accurate price, you should get a second opinion. Inquire at the local parts store and they should be able to provide you with the correct price.
The labor time for replacing the distributor is 0.7 hour.
ELKOOLG1
  • 1998 HONDA CRV
Engine Mechanical problem
1998 Honda CRV All Wheel Drive Automatic
My car keeps shutting off, no lights, no overheating, just off. I apparently need a new distributor. How much should that cost, and what is it? Any help would be wonderful
F4I_GUY
  • 3,302 POSTS
A distributor is a unit that distributes ignition spark to your cylinders. It also has a few sensors in there that measures engine position.
A new distributor (aftermarket) is about $200-300. From Honda, it's about $500+.
