alternator will not charge fully
HONDA ACCORD
SHONNIE
1991 honda Accord w/ automatic transmission 191000 miles. first the speedometer and rpm goes hay wire, then the trans start buckin and it will not pick up speed then all the power goes out and when i cut it off it will not do anything. The car has no power. I chanded the alternator and it worked fine for 4 days and then it did the same thing. Changed the transducer and now the alternator is bad again. About to change the alternator again but do anyone have a clue on what could be the problem? Today replaced the alternator again and took it to the auto zone and the said the alternator is not charging full it has a very low charge.
Sep 28, 2007 at 7:20 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
You know I have seen this problem with a string of bad alternators. I assume they are rebuilt. You have mentioned nothing about the condition of the battery.
Oct 1, 2007 at 7:40 AM
