2001 Honda Accord check engine light
OZZY0086
  • 2001 HONDA ACCORD
2001 Honda Accord 6 cyl Front Wheel Drive Automatic
i have a 2001 honda accord and the check engine lght came on when it did the tcs light came on and the transmission light that tells u if ur in drive started to blink what does that mean
Friday, February 27th, 2009 AT 1:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to use a diagnostic scanner to retrieve the engine codes. This will help point in the right direction to start diagnosing the issue. Most part stores will run the codes for you free of charge. Post the codes you get and we can better assist you.
Thanks for using 2CarPros. Com!
Friday, February 27th, 2009 AT 2:09 AM
