1994 Honda Accord
LYNDSIA999
  • 1994 HONDA ACCORD
  • 4 CYL
  • 171,000 MILES
I recently had quite a bit of work done to my honda, water pump, timing belt, oil gasket repair, spark plugs, etc. Since i've had all this fixed though my heater doesn't seem to heat well, even after 15-20 min of warming up, it's blowing cold air. What areas do I need to look at or could it possibly be as simple as a thermostat? Thanks for your help!
Sunday, January 20th, 2008 AT 4:42 AM
  • 31,937 POSTS
Hi there,
I would hope that after all that work the thermostat was changed. If not change it. Also check that the heather hoses are getting hot. If not check that the heater tap is working and the controller is functioning properly. Start there.
Mark (mhpautos)
Sunday, January 20th, 2008 AT 4:47 AM
Related General Content
